Server Version#: 1.43.5.11079
I updated to this version, and Enable Loudness is consuming all my CPU causing temps to spike and warning about throttling on a i7-8700 causing CPU temps of 100*C.
How can I disable this server wide?
Settings - [server name] - Library - “Analyze audio tracks for loudness”
If you want to keep it active for music, but disable it for video, edit all the video libraries and disable it on each library’s Advanced tab.
thanks.
Is there a reason the iGPU can’t be used? My CPU has been beat up thanks to this feature. 6K movies and when it hit my 4K library my CPU was brutalized.
It’s an audio analysis, not a video transcoding.
Understood. I wish this feature was not enabled by default.
