EPG completely confused - showing programmes for other channels
Server Version#: 1.18.0.1913
Player Version#: 7.23.0.13018
EPG on Fire TV shows programmes for other channels, misses out certain channels completely. Web Player works fine. This is since from the previous version 7.21.x
Fire TV:
Web player:
Note on Fire TV BBC 1 South is listed before BBC 1 London, BBC 1 South showing programmes for BBC 2 (completely missing), and ITV (completely missing).
Behind the scenes, I’ve mapped BBC1 London to BBC1 HD because I want HD channels to be listed in order rather than having to scroll down past all the SD channels. This has worked fine and does still on the web player.
Thoughts? Thank you.
Just seen that v7.24 addresses this issue - now we just need to wait for the rollout to hit the Amazon App Store - 7.23 took a long, long time for some reason…
Tried it today with 7.24.3 build running NVidia Shield.: same problem. If I remove the offending channels, all seems well. As soon as I add them back in again same problem. Please, please, can this be fixed?
@sa2000 would be grateful if you could raise this with the developers, per comments above, even with the latest release on Android TV, the channels are still showing programmes from different channels and some channels missing - screen shots above still apply. Note I’ve completely reset my Plex Server and uninstalled Plex Player with no improvement.
Many thanks.
