Error Module did not self-register
Hello everyone,
I’ve been trying to get the headless Pi with Plexamp to work but I’m stuck.
When deploying,
node /home/lyrucorpmuziektaart/plexamp/js/index.js
I get the error below.
Now I have seen a similar topic here with someone not having the ‘right’ version of node but that doesn’t seem to be the case here, I’m on v20.
Thanks for your help!
lyrucorpmuziektaart@muziektaart:~ $ node plexamp/js/index.js
node:internal/modules/cjs/loader:1302
return process.dlopen(module, path.toNamespacedPath(filename));
Error: Module did not self-register: ‘/home/lyrucorpmuziektaart/plexamp/treble/linux-arm64/treble.node’.
at Module._extensions…node (node:internal/modules/cjs/loader:1302:18)
at Module.load (node:internal/modules/cjs/loader:1081:32)
at Module._load (node:internal/modules/cjs/loader:922:12)
at Module.require (node:internal/modules/cjs/loader:1105:19)
at require (node:internal/modules/cjs/helpers:103:18)
at 32983 (/home/lyrucorpmuziektaart/plexamp/js/index.js:2:414228)
at a (/home/lyrucorpmuziektaart/plexamp/js/index.js:2:3227471)
at 90493 (/home/lyrucorpmuziektaart/plexamp/js/index.js:2:408387)
at 59825 (/home/lyrucorpmuziektaart/plexamp/js/index.js:2:392698) {
code: ‘ERR_DLOPEN_FAILED’
Node.js v18.13.0
Means a mismatch of node version.
