EventSourceClient/pubsub does not support NAT64
Server Version#: v1.32.5.7349-8f4248874
Player Version#: v4.113.2 (web app)
Given AWS’s recent announcement to charge for public IPv4, I’m trying to run PMS in an environment with no v4 internet access. NAT64 allows all the HTTP parts of Plex to work - including streaming locally over IPv4 - however updating a Plex library requires pubsub, which appears to be trying to connect directly to v4 IPs:
Aug 15, 2023 22:48:44.169 [139744931466040] INFO - Plex Media Server v1.32.5.7349-8f4248874 - Debian GNU/Linux PC x86_64 - build: linux-x86_64 debian - GMT 00:00
Aug 15, 2023 22:48:44.170 [139744931466040] INFO - Linux version: 12 (bookworm), language: en-US
Aug 15, 2023 22:48:44.170 [139744931466040] INFO - Processor: 2-core AMD EPYC 7571
Aug 15, 2023 22:48:44.170 [139744931466040] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Aug 15, 2023 22:48:44.170 [139744931466040] INFO - /usr/lib/plexmediaserver/Plex Media Server
Aug 15, 2023 22:48:44.334 [139744984267408] INFO - Running migrations. (EPG 0)
Aug 15, 2023 22:48:44.458 [139744984267408] INFO - Running migrations. (EPG 0)
Aug 15, 2023 22:48:44.912 [139744909527864] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Aug 15, 2023 22:48:44.912 [139744909527864] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Aug 15, 2023 22:48:44.918 [139744906398520] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability
Aug 15, 2023 22:48:44.918 [139744906398520] WARN - [MediaProviderManager] Unrecognized MediaProvider feature: availability-platforms
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 45.33.103.230 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 139.162.40.38 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 172.104.216.125 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 45.56.91.121 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 72.14.179.64 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 178.79.177.129 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 172.105.29.107 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 178.79.165.194 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 139.162.75.196 failed: Operation timed out.
Aug 15, 2023 22:48:57.776 [139744872327992] WARN - [PubsubServerManager/process] Connection to 172.105.245.178 failed: Operation timed out.
Aug 15, 2023 22:48:58.362 [139744878656312] WARN - MyPlex: attempted a reachability check but we're not yet online.
Aug 15, 2023 22:48:58.443 [139744880765752] INFO - [CERT/OCSP] Successfully retrieved response.
Aug 15, 2023 22:48:59.934 [139744895531832] INFO - LibraryUpdateManager path watching is disabled
Aug 15, 2023 22:49:07.513 [139744927247160] ERROR - [EventSourceClient/pubsub/178.79.177.129:443] Retrying in 15 seconds.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 172.105.203.197 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 72.14.179.64 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 172.105.96.32 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 45.56.91.121 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 192.46.236.7 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 178.79.177.129 failed: Operation timed out.
Aug 15, 2023 22:49:52.530 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 139.162.219.82 failed: Operation timed out.
Aug 15, 2023 22:49:52.531 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 172.104.44.222 failed: Operation timed out.
Aug 15, 2023 22:49:52.531 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 172.104.24.90 failed: Operation timed out.
Aug 15, 2023 22:49:52.531 [139744925137720] WARN - [EventSourceClient/pubsub/178.79.177.129:443/PubsubServerManager/getNextWorkingHost/lhr/process] Connection to 45.56.116.228 failed: Operation timed out.
Aug 15, 2023 22:49:52.531 [139744925137720] ERROR - [EventSourceClient/pubsub/178.79.177.129:443] Retrying in 30 seconds.
Short of running a proxy for these connections, is there anything obvious I’m missing? If there’s a way to get this library to resolve AAAA records and connect to a v6 IP, this connectivity should work without needing to go whole hog with IPv6 support (yet).
