Has anyone got any information regarding the use of external inputs to a channel, in particular I’m thinking key presses for triggering events in a channel such as pausing a stream etc. I’ve been looking all day and found nothing.
I’m mainly thinking of OPHT clients for what it’s worth.
So as background, I have an video streaming channel with multiple ‘channels’. I want to be able to change which ‘channel’ or stream I’m watching whilst already in the stream.
So I’m okayish with Python and I’ve done some modifications to this channel already. The channel already contains methods for searching and calling up the stream URLs etc. I’m now trying to figure out how i can program to detect the key presses from my remote/keyboard.
Unsure how much of this can be done in the channel though.
Though I am not quite sure what you mean by “an video streaming channel with multiple ‘channels’.”, you cannot control the Plex environment from a channel plugins. Are you wanting some shortcut key to switch between between directory items of a channel from the within the play screen?
All you do in a Plex channel is create directories to organize the media and pull the metadata to populate the media listings in each directory. Then you create media containers (usually in a URL service) that contain all the data about each video stream you want Plex to play.
Each Plex player app controls the environment. Plex channels just create an XML document for each directory with all the metadata. Each Plex player app is programmed to read that XML and display the channel directories and determine how to play the media based on the details shown in the media container. Any remote control/keyboard options in channels are part of and controlled by the Plex player app.
Ultimately, you would need to refer to the section of the forum for the Plex player app you are using and see if they offer any keyboard options that can be used within in channels.
Thanks for the reply. The channel contains multiple directories and there is a directory that has multiple media listings all numbered like channels. I wish to be able to change media listings whilst playing one of them.
So to rehash what you’ve said. PMS parses the channel functions and creates an xml containing directories/media listings. The client then reads this xml and creates the directories/media listings for the viewer?
I have also posted in the OPHT forums about getting the keyboard info.
