I upgraded today from 1.18.9.2578 to 1.19.1.2589 and this is the first upgrade i’ve ever performed where PMS did not restart after the upgrade was completed. I had to manually start the server with systemctl. Interestingly, there’s a note in the release notes that says “(Ubuntu/Debian) Respect autostart after upgrade for all versions 1.18.5 and above” but my experience was the complete opposite. Here is the output from the ugprade if it helps (i didn’t see anything suspect)
(Reading database ... 376958 files and directories currently installed.)
Preparing to unpack plexmediaserver_1.19.1.2589-2de7f3266_amd64.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.19.1.2589-2de7f3266) over (1.18.9.2578-513b381af) ...
Setting up plexmediaserver (1.19.1.2589-2de7f3266) ...
PlexMediaServer install: PlexMediaServer-1.19.1.2589-2de7f3266 - Installation starting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library/Application Support
PlexMediaServer install: Temp Directory: /dev/shm (set in Preferences.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Transcoding HW: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: PlexMediaServer-1.19.1.2589-2de7f3266 - Installation successful. Errors: 0, Warnings: 0
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for desktop-file-utils (0.23+linuxmint8) ...
Processing triggers for mime-support (3.60ubuntu1) ...
