Fanart possible?
I think someone asked this before, and the answer was no, not with the AppleTV.  But I was just checking some of the movies in the store under the normal movies app, and noticed the movie The Impossible was listed as one of the top rentals/purchases right now.  I was curious why, since it's been out a while.  I assume it was on sale.  Anyway, when I clicked on the movie, this (check attachment) came up on what would be the equivalent of the pre-play screen on the Trailers app.
Is there a way that this sort of artwork can be included in the Trailers app as well?  I just hadn't seen any movie like that before.  I just checked, and most don't.  The Heat (Sandra Bullock flick) also has background art like that as well.
Just curious.
Edit: Seems the image is upside down for some reason.  Anyway, you get the idea.
Good Find!
Would be a very cool feature that is for sure
Cheers Rob.
I also think it's using the same mechanism that iTunes uses for the color of the text.  For The Impossible, all the labels are colored in Orange, somewhat matching the color scheme of the artwork.  The Heat, which has a heavy red color in the artwork, has red colored labels.  Interesting...
Has anyone else seen this before?  I would think it's fairly new, and studios are starting to add appropriate artwork?
That type of background has been showing up for select iTunes movies since the day before the last apple event. Pacific Rim has it I believe amongst others.
Yeah, I've noticed some others since I spotted those first couple.  It would be nice if PlexConnect could do something similar.
...it's an iOS 6 feature as far as I know. Roidy is looking into it.
Yeah it is iOS 6 and is currently causing a few grey hairs as to its proper mechanism!
+1
This would be very nice! :)
would be freaking awesome!!  :D
 still miss the movie lineup below the info (with simular movies) is that in the game plan btw? (of topic sry i know am just so excited  :rolleyes: )
Wow, very cool find, this would definitely be an awesome addition to an already fully-featured app.
Would we need an agent to provide the appropriately sized images?
Or have the PMS transcode them.
iOS 6 is EXTREMELY picky about the images for these!!
So you dont have to stand on your head.
Check out the PrePlay Screen for “Man of Steel”. It looks like they changed the design again (unless it is one-off). The background image begins just to the right of the movie poster. Looks better I think.
Check out the PrePlay Screen for "Man of Steel". It looks like they changed the design again (unless it is one-off). The background image begins just to the right of the movie poster. Looks better I think.
It's tough to tell, but it looks to me like the image takes up the entire top and the fading is in the image.
I don't know if it's helpful, but I intercepted the banner from Man of Steel.
Here's a link to the file
https://www.dropbox.com/s/whbvtgj37otk2z9/image1280x324_2.jpeg
Well that shows that it is just a fluke of that particular banner image.
I edited the MoviePrePlay.xml template to play with the image header, but it doesn't look very promising.
I replaced the tag with and then added:
  #ff0000
  #00ff00
    {{IMAGEURL(Video/thumb::768)}}
The result looked like this
I tried to use Video/art, but I couldn't get things to show up right.
Something to notice is the title is gone from the top so the title of the movie would probably have to be in whatever picture is put up there or things would look funny.
what happens if u point it to the fan art instead of the cover art?
I couldn't get it to show up.  It looked like it was drawing everything off the left side of my screen.  The same thing happened when I tried to scale the poster art to anything but 768.  I'll play around with it a bit more maybe.
