i had to disable the atv check code from the progressionbar to not get a bunch of error code in terminal window.. and i guess the code neds to be added to the banner check aswell
The thing that jumped out at me is that the variable name has changed since the progress code you merged in.
it should be {{CUT(^aTVFirmareVersion:CUT:=CUT|6.0=)}} instead of {{CUT(^aTVVersion:CUT:=CUT|6.0=)}}
really really awesome! I can't wait to get this :)
It looks very nice, my only idea would be perhaps to design the list screen of the seasons with black under the text for better reading. perhaps it looks a little bit confusing with the black boxes of the seasons..
but again very very nice work
Will there also be fan art in the pre play screen?
The black under the text is unfortnunally not possible , the picture is the fanart directly taken from the PMS and due to limitations to the iOS it will not allow us to put anything in wherever we want yet.. the black boxes are part of iOS and they are "invisible" when u use the standard background thats why u havent noticed them
the Season list will not be added to github yet due to many limitations still.. it still depends to much on fanart resolution etc.. so until we find a way to get PMS to trascode it to right size it will not be added..
i did some changes to the preplay screen aswell.. added some stuff but i tried to add the banner to the pre play aswell but it will not work cause the banner picture in that section require a resolution that banner does not has as standard and will also be need to be trascoded in order to work properly...
the the one that we try to get on git will be the one with the episode list .. the other ones will be on hold...
taller i will pm u when i get home, am still at work
