[Feature Request] headphone double click song skip Android
When I double click the headphone button on my headphones the music in the Android player skips a song. Single click does play/pause. Google Music/Spotify do this and I believe it’s just a basic Android API hook you can override.
this feature would be greatly appreciated. Also I would like to add three clicks for moving back a song.
I think the iOS version of plex already supports it.
Whilst you’re waiting for integrated support, a workaround could be to try apps like https://play.google.com/store/apps/details?id=se.jays.headsetcontrol
Or is the problem that Plex won’t even recognise them?
This solved the problem for me
