Feature Request: Make "next" episode fewer clicks away
Is it possible to make the next episode of a tv show easier to get to?
right now after you watch an episode it shows you what you just watched, and a line up of the first five episodes. is there a way to put in a 'play next' button, or make the last watched episode appear either in the 1st slot or 3rd slot with respective previous/next episodes on either side? this way watching episode heavy seasons can be less cumbersome.
thanks for all the time and work you put into this program as well as the time you spend maintaining these forums. I really appreciate it.
-Beau
For those, I just press play on the Show list and don't go into the PrePlay screen, thsi way you are taken back to the list and just move to the next show and press play.
this is exactly how i do it at home :)
at one point i have even disabled the ok button so i dont need to go to the pre play :P
When they introduced the pre-play screen into the ATV-native Plex app, I attempted to argue (at great length) that it wasn't necessary. I was told to just use the Play button on the remote, but that's not that simple; it's a muscle-memory thing, and requires training yourself and others. Not to mention that anyone using a non-Apple remote probably doesn't have a separately-mapped Play button, so can't do it anyway.
I still don't like it, but I've grown to deal with it I guess. :)
The point about the shows at the bottom not lining up with what you just watched is valid though, especially on long seasons if 20+ episodes.
You'll probably like this thread:
https://forums.plex.tv/index.php?/topic/73682-%5BFeature-Request%5D-TV-Post-Play-screen-ala-Netflix
Please comment +1 in there :)
