[Feature Request] Manually add channel to tuner
Server Version#: 1.13.8.5395
I live in an area that my CBS transmits on 2 different physical channels (VHF is transmitted on channel 4 the main channel and the UHF is transmitted on channel 47 a re-transmitted) both have a virtual channel number of 4. This was done because when everything went digital too many people lost the VHF channel so CBS started re-transmitting on the UHF band. The thing is that the VHF channel is to the east of where I live and the UHF channel is south of where I am along with every other channel that I can get. The problem is the that plex automatically adds the physical channel 4 and not 47. I get a much better signal from the UHF channel and if I redirect my antenna more to the east I lose all my other channels. When I used Argus TV before I moved to plex I was able to manually tell it which channel to use for CBS. Is there a way to do this for Plex?
If this isn’t possible now can this be added as a feature?
