[Feature Request] Plexamp Equalizer Reset
There is a pretty big possibility that I could be completely missing this in the settings somewhere - and if I am, please let me know - but an equalizer reset button would be a fantastic addition. Having to zero out every band when I want to rewrite my EQ curve from scratch (I do this shamefully often…) gets kinda monotonous.
Of course, I could just disable the equalizer entirely, but as someone who uses the custom presets, that would mean disabling those as well instead of being able to clear the equalizer for only one device.
Just a general quality-of-life feature that wouldn’t go unappreciated :slight_smile: Thanks for considering!
You can reset each band by tapping/clicking on each band’s label.
It pains me that I was unaware of this until just now… Well, that’s that solved I suppose.
Thanks for the response, and thanks for all the great work! Plexamp rocks :smiley:
Thanks for the kind words!
