It would be good to extend the options with restrictions . Can you extend the options by allowing you the options of adding labels or ratings the user can’t see, not just what they can see. It could make it easier is some cases where you only want to remove 18 rating movies or shows. Also it would be good if you could apply a predefined filter. For example you only want to give a friend access to moves between 1950 and 1970 or a specific Genre.
duplicate feature request
closing
please respect the rules for this subforum
- search first if the request has already been posted before
- only one feature per post
