Fire TV stick show HD only in guide?
Server Version#: 1.19.4.2935
Player Version#: Fire TV Stick (OS 5.2.7.3) running Plex 8.3.1.19108
Tuner Make/Model: HD Homerun Prime HDHRC-CC, firmware 20200521
Guide/Lineup name: Spectrum Digital
Using XMLTV?: No
Channel number/Name:
Is there a way to filter the guide channels on a Firestick to just show the HD channels? When I log into plex from a computer, I have the option at the top of the guide that allows me to just show HD channels, but I can’t find this on the Fire TV guide. Is this not available or am I just not looking in the right place? On the fire stick, when I first go into the guide, I get a popup that says to hold the center button on the remote for more guide options, but when I do that nothing seems to pop up for additional options.
I could disable all the non HD channels in the DVR setup, but I stream to mobile devices and non HD channels work better if their connection is less than stellar so I’d prefer not to.
Not sure if this should be a feature request, or if I’m just not looking in the right place? I did some searching for this in the forums, but it’s either not there, or I haven’t hit on the magic combination of keywords yet. Any help would be appreciated.
Thank you!
