First Channel Issue
I’m currently making my first channel which Is going well. I’m able to pull the channels onto the first page. However I now want to moved channels onto a sub page using the mainmenu as a menu. Could someone point me in the right direction as to where I am going wrong?
Here is my working code: (The important bit)
@handler(PREFIX, TITLE, thumb=ICON, art=ART)
def MainMenu():
    oc = ObjectContainer(title2=TITLE, no_cache=True)
    xml = XML.ElementFromURL(XML_URL)
    for node in xml[0][0]:
        title = node.get('title')
        thumb = node.get('hdposterurl')
        #genrel = node.get('genrel')
        url = node.get('url')
        #ishd = node.get('ishd')
        active = node.get('active')
        if (active == 'true') or (active == '1'):
            oc.add(
                CreateVideoClipObject(
                    title=title, thumb=thumb, url=url
    return oc
When I change it to the following It then fails to respond
@handler(PREFIX, TITLE)
def MainMenu():
    oc = ObjectContainer()
    oc.add(DirectoryObject(key=Callback(ChannelOpt1), title="Channel 1")))
    return oc
@route(PREFIX +'/ChannelOpt1')
def ChannelOpt1()
            oc.add(
    return oc
@jnymris could be anything, better check the log files. If anything goes wrong, there’ll always be an error message.
I’m spotting a missing colon after def ChannelOpt1().
