First plugin - no log errors - doesn't show up on channel list
Ok, makes sense it couldn’t find the PMS thing to import. See, I never found that error when I was looking.
At any rate it’s now working, even show the menu item this time ha ha. Thanks.
Only problem now is that the settings screen still won’t come up on my Droid plex, just shows an empty screen. But not too worried about it really. As long as the app works I guess :slight_smile: That might also be a Droid plex app problem.
Quick question, is there anyway to do a confirmation window when the shutdown button is clicked? I looked through the API wiki and only found the input box and the MessageContainer.
Yeah I just tested and the settings screen works on the Roku, so it must be botched on the Droid app for plex :slight_smile: All working then thanks! :slight_smile:
Just if you know a way of doing a confirmation popup that would be really helpful :slight_smile:
You can use a PopuopDirectoryItem in place of a DirectoryItem but I’m not sure which clients support it and which ones don’t.
Take a look at the code for the unRAID plugin I wrote. I’ve basically abandoned the plugin but the code was functional and should provide you with what you need.
Awesome, thanks. I’ll give it a try :slight_smile: Thanks for the help.
