Volts
1
Plex is displaying the Frame Rate as 23.97599983215332 in Plex Web and other apps.
23.976 would be adequate.
I’m curious where 23.97599983215332 is coming from. It isn’t a better approximation of 24000/1001.
I bet it’s 23.976, stored in a float, and then displayed with too many sig figs.
I think it’s just cosmetics.
Compare to the number appearing in the Plex media info XML of the same item.
Volts
3
Agreed! Totally cosmetic.
Googling for 23.97599983215332 is fun. Most hits are Plex, but there are a few from other apps - likely with the same format/display issue.
