I haven’t been able to access any movies on the G2g.fm site for about 2 weeks now. Before I had no problems.
I have tried everything from uninstalling and reinstalling to checking firewall settings and changing browser with no answer. It still keeps saying, channel is not responding. I don’t think my Isp service is blocking this. I haven’t had any problems using Let Me Watch This. I can access movies that are accessible without any issues. Could someone help me. Thank you very much in advance.
If you this from “@JohnEngland , go to your Plug-ins/G2Gfm.bundle/Contents/Code/init.py file, open it with a text editor (notepad), find the 3 instances of 4do.se, and change it to moviez.se” you should get it to work if you need any more help go plex channels and the G2G.FM forum
I followed your instructions to the letter and it worked like a charm. Thank you very much for that needed help. I’ve tried everything I knew and then some but you sir are the man. Thank you so much.
totally awesome!!! Thank you for this fix!
I’m a happy camper again!
Dang I wish this would work again…
I’m jonesing for a good movie channel
