Generating a client from openapi spec?
Has anyone tried to generate a client from the published openapi spec? I had to wait for my generator to support openapi v3.1, but it doesn’t work:
error generating code: error generating code for type definitions: duplicate typename 'MediaContainer' detected, can't auto-rename, please use x-go-name to specify your own name for one of them
And indeed, the spec contains two definitions. One called “MediaContainer” (line 48), and one called “mediaContainer” (line 1438).
answering my own question: the spec contains 2 mediaContrainer types: one’s called “MediaContainer” and one’s called “mediaContainer”, which tripped up my code generator.
Already found one bug in the spec: components.schemas.librarySection.properties.hidden is defined as a bool, but the implementation returns an integer.
