Server Version#: Can’t get it to load. plexmediaserver-1.43.2.10687-563d026ea.x86_64.rpm
sudo dnf install -y plexmediaserver
Last metadata expiration check: 0:01:59 ago on Tue 26 May 2026 12:22:24 PM CDT.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
plexmediaserver x86_64 1.43.2.10687-563d026ea PlexTv 103 M
Transaction Summary
Install 1 Package
Total download size: 103 M
Installed size: 212 M
Downloading Packages:
plexmediaserver-1.43.2.10687-563d026ea.x86_64.rpm 21 MB/s | 103 MB 00:04
Total 21 MB/s | 103 MB 00:04
Problem opening package plexmediaserver-1.43.2.10687-563d026ea.x86_64.rpm
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing ‘dnf clean packages’.
Error: GPG check FAILED
Followed the manual install. Removed the old plex GPG key before.
