GPU or no?
Not any other chip. None of the 9th gens. A lot (possibly all) of the 8th gens.
Seems like overkill for 1080p transcoding though.
If I may reply at the personal level?
I don’t understand the need for the 9th gen personally.
The -8xxx CPU is not going to be consumed doing video .
The i5 itself will die out long before with everything else it’s doing such as audio and remuxing. If any subtitles come into play, hardware ASIC capability afforded by the -9xxx is a moot point.
I have both a -7700 and an -8509g. I can’t kill either of them processing video.
The biggest load I can place on them is all 6 players doing 2160p HEVC HDR 60+ Mbps -> 1080p SDR 20 Mbps.
Yea, I just thought it was worth mentioning, as the chip will fit and the OP seems determined to max out the potential
I personally believe
  1. it’s beyond the point of beneficial return
  2. It’s not worth voiding the warranty.
I deal with the QNAPs here.
If they dont offer a -9xxx for a model then there won’t be any firmware or runtime library support for it either.
I agree with both points.
For this reason, I ended up buying a nas without an ASIC entirely.
After all, pretty much any CPU can transcode 1080p properly, but non can 4K (unless SDR)
My thoughts about 2160p curation are really simple:
  1. If you can’t play it natively on anything – why have it ?
  2. If you have a NAS, and have both 2160p and 1080p devices, then keep both resolutions. Buy the disk space for it. Don’t be cheap. This isn’t a commodity hobby.
DirectPlay & DirectStream (audio only) are the way to go.
EDIT:
-OR- spend the money for the stronger players (Nvidia Shield Pro 2019 for one) which can DirectPlay 2160p and tonemap it to 1080p without blinking.
Yea, same.
Ive just turned off transcoding and told people using my server to upgrade their clients. The ATV 4K does the same job
Yes it does. The ATV 4K will do the same thing. I actually have both.
I find the Nvidia does better with audio into the Onkyo (passthrough). Apple does everything as LPCM output
One more piece of info:
i5-9500 has the UHD 630 GPU/ASIC
Ref: https://ark.intel.com/content/www/us/en/ark/products/134895/intel-core-i5-9500-processor-9m-cache-up-to-4-40-ghz.html
i5-8500 has the same UHD 630 GPU/ASIC
Ref: https://ark.intel.com/content/www/us/en/ark/products/129939/intel-core-i5-8500-processor-9m-cache-up-to-4-10-ghz.html
There is no net gain from the GPU perspective except the ‘turbo’ speed is a little bit higher in the CPU portion.
If the CPU is running at that clock rate, it’s not a GPU problem – It’s a subtitle problem.
Thanks guys…Several people on the QNAP forum, are putting in i9-9900 (not i5) chips. I am just gathering data as 1) my existing 673 (non intel based) sucks for PLEX and 2) Trying to ensure that I get some level of future proofing if I spend the $$ on a new box. Looks like QNAP will be coming out with this shortly with a XEON processor. Appreciate the help everyone!
The ASIC breaks using that chip, even if the CPU works.
If I’m reading this correctly, you are saying that transcoding a high bitrate 7.1 audio (DTS MA or Dolby TrueHD) to EAC3 or Stereo takes about 1500+ passmark?
