Hi there,
I have purched PlexPass to use hardware based transcoding on my Plex Server running on Debian with Asrock J4205-ITX mainboard.
When I switch hardware acc off, then 4k HEVC encoded videos do not run smoothly - not on Windows WebClient nor on FireTV Stick (V2).
Here are the log for speed and CPU load with an example movie when HW accel is off:
Windows:
HW off -> Windows Webclient:
root@omv:~# sar 1 10
Linux 4.18.0-0.bpo.1-amd64 (omv) 01.11.2018 x86_64 (4 CPU)
11:02:52 CPU %user %nice %system %iowait %steal %idle
11:02:53 all 93,25 4,00 2,25 0,00 0,00 0,50
11:02:54 all 91,48 7,02 0,50 0,00 0,00 1,00
11:02:55 all 91,75 6,75 0,75 0,00 0,00 0,75
11:02:56 all 90,23 8,02 0,50 0,00 0,00 1,25
Nov 01, 2018 11:02:55.940 [0x7f19987ff700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:02:56.500 [0x7f198bdb7700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:02:57.013 [0x7f198bdb7700] VERBOSE - * speed => 0.8
Nov 01, 2018 11:02:57.470 [0x7f199ffff700] VERBOSE - * speed => 1.2
Nov 01, 2018 11:02:58.019 [0x7f198bdb7700] VERBOSE - * speed => 0.7
Nov 01, 2018 11:02:58.520 [0x7f199c7ff700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:02:59.071 [0x7f199ffff700] VERBOSE - * speed => 1.1
Nov 01, 2018 11:02:59.558 [0x7f198bdb7700] VERBOSE - * speed => 0.9
Nov 01, 2018 11:03:00.066 [0x7f19adfff700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:03:00.586 [0x7f19aafff700] VERBOSE - * speed => 0.9
See - that CPU load is under full load.
Same with FireTV:
11:06:45 CPU %user %nice %system %iowait %steal %idle
11:06:46 all 78,45 20,30 1,00 0,00 0,00 0,25
11:06:47 all 77,94 21,30 0,50 0,00 0,00 0,25
11:06:48 all 80,00 17,75 0,50 0,00 0,00 1,75
11:06:49 all 81,70 17,54 0,50 0,00 0,00 0,25
11:06:50 all 76,50 22,50 0,75 0,00 0,00 0,25
^C
Durchschn.: all 78,92 19,88 0,65 0,00 0,00 0,55
root@omv:~# grep -i “speed =” “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log”| tail -10
Nov 01, 2018 11:06:47.630 [0x7f19adfff700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:06:48.265 [0x7f199ffff700] VERBOSE - * speed => 0.7
Nov 01, 2018 11:06:48.951 [0x7f198bdb7700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:06:49.322 [0x7f19adfff700] VERBOSE - * speed => 0.3
Nov 01, 2018 11:06:49.999 [0x7f198b5b6700] VERBOSE - * speed => 1.0
Nov 01, 2018 11:06:50.419 [0x7f19adfff700] VERBOSE - * speed => 0.7
Nov 01, 2018 11:06:50.874 [0x7f199c7ff700] VERBOSE - * speed => 0.6
Nov 01, 2018 11:06:51.516 [0x7f19adfff700] VERBOSE - * speed => 1.1
Nov 01, 2018 11:06:52.012 [0x7f199ffff700] VERBOSE - * speed => 0.6
Nov 01, 2018 11:06:52.458 [0x7f198bdb7700] VERBOSE - * speed => 0.5
When I switch HW accel on, playing with Windows is no problem:
root@omv:~# sar 1 3
11:00:19 CPU %user %nice %system %iowait %steal %idle
11:00:20 all 9,18 0,00 15,22 5,56 0,00 70,05
11:00:21 all 8,37 0,00 15,02 5,91 0,00 70,69
11:00:22 all 8,70 0,00 14,49 6,76 0,00 70,05
Durchschn.: all 8,75 0,00 14,91 6,08 0,00 70,26
Nov 01, 2018 11:00:21.400 [0x7f199ffff700] VERBOSE - * speed => 2.0
Nov 01, 2018 11:00:21.929 [0x7f19adfff700] VERBOSE - * speed => 2.6
Nov 01, 2018 11:00:22.434 [0x7f199ffff700] VERBOSE - * speed => 1.9
Nov 01, 2018 11:00:22.941 [0x7f19adfff700] VERBOSE - * speed => 2.2
Nov 01, 2018 11:00:23.458 [0x7f199ffff700] VERBOSE - * speed => 2.3
Nov 01, 2018 11:00:23.972 [0x7f19adfff700] VERBOSE - * speed => 2.0
Nov 01, 2018 11:00:24.502 [0x7f199c7ff700] VERBOSE - * speed => 2.3
Nov 01, 2018 11:00:25.011 [0x7f19aafff700] VERBOSE - * speed => 2.0
Nov 01, 2018 11:00:25.530 [0x7f19987ff700] VERBOSE - * speed => 2.4
Nov 01, 2018 11:00:26.046 [0x7f19aafff700] VERBOSE - * speed => 2.1
CPU load dramatically decreased!
But when playing with FireTV there is still “server too weak” messages in Plex Player. But CPU load ist pretty much the same as when I’m using the Windows Client whereas overall speed is still under 1.0
Fire TV with HW accel on:
11:09:35 CPU %user %nice %system %iowait %steal %idle
11:09:36 all 19,15 0,00 7,71 2,74 0,00 70,40
11:09:37 all 17,33 0,00 6,68 2,72 0,00 73,27
11:09:38 all 17,57 0,00 7,18 2,72 0,00 72,52
11:09:39 all 17,82 0,00 6,68 2,72 0,00 72,77
^C
Durchschn.: all 17,97 0,00 7,06 2,73 0,00 72,24
Nov 01, 2018 11:09:37.226 [0x7f19adfff700] VERBOSE - * speed => 0.8
Nov 01, 2018 11:09:37.770 [0x7f199c7ff700] VERBOSE - * speed => 0.5
Nov 01, 2018 11:09:38.323 [0x7f19adfff700] VERBOSE - * speed => 0.7
Nov 01, 2018 11:09:38.865 [0x7f199ffff700] VERBOSE - * speed => 0.6
Nov 01, 2018 11:09:39.350 [0x7f19adfff700] VERBOSE - * speed => 0.6
Nov 01, 2018 11:09:39.899 [0x7f198adb5700] VERBOSE - * speed => 0.7
Nov 01, 2018 11:09:40.505 [0x7f199ffff700] VERBOSE - * speed => 0.9
Nov 01, 2018 11:09:41.046 [0x7f199ffff700] VERBOSE - * speed => 0.8
Nov 01, 2018 11:09:41.600 [0x7f198adb5700] VERBOSE - * speed => 0.6
Nov 01, 2018 11:09:42.140 [0x7f19adfff700] VERBOSE - * speed => 0.7
What can cause the bad FireTV performance? Why ist there no difference compared with “HW accel” off. As you can see CPU is not the limit with “HW accel” on.
To be clear: I’m only talking about 4k HEVC encodes movies. The rest ist working fine.
Any hint greatly appreciated.
Thanks and regards
Joerg
