Having plex on 2 ssds
@cayars said:
I’m glad you got it worked out but you might not have needed to use a symlink. Depending on your version of Plex (I’m on windows) there is an ADVANCED option under the server genenal tab “The path where local application data is stored”
All you do is create a new directory on the new drive such as D:\PLEXDATA
change the option mentioned above to now read D:\PLEXDATA
shut down the server
navigate into the Plex folders and copy/move the folder Plex Media Server to the new location so it looks like this
D:\PLEXDATA\Plex Media Server
Restart server
I have all my meta data on a dedicated 1TB SSD.
I will keep that in mind for next time. I am also on windows. Plus, now if anyone else ever has this issue they have 2 options. Thank you both!
