HDR tone mapping broken again?
Server Version#: Version 1.25.2.5319
Player Version#: android
Using PMS as a docker on my Unraid. I remember there was a problem with HDR tone mapping the spring 2021.
https://forums.plex.tv/t/4k-hdr-hevc-hw-transcoding-is-broken-on-i5-11600k-rocket-lake/707057/46
Now I notice I have the same problem again. Turning it of making the transcode use HW again.
What is the last working server version? Is this problem reported?
/Söder
Yes, it’s an issue. See this thread.
Thanks. Great that I’m not the only one.
/Söder
Downgrade intel compute runtime to 21.49.21786 and it should work
As I asked about in the other thread, if using Plex docker on Unraid, and the Plex docker is the only thing that’s been updated, is this something that is builded in to the Plex docker then?
Plex Docker (at least Linuxserver’s version) automatically update drivers to the latest stuff when updating image
If something’s broken after updating then yeah, it’s 100% inside the container
There’s an issue on their github talking about this. They’re working on this
Plex tone mapping for transcoding 4K HDR to 1080p does not use hardware transcode because drivers are missing in the container. · Issue #297 · linuxserver/docker-plex (github.com)
Thanks. This also explains why it doesn’t work to downgrade for me, it the intel driver already has been updated. Strange some other says it works for them to downgrade then…
/Söder
Try using this image
lsiodev/plex:amd64-1.25.2.5319-c43dc0277-pkg-c2e7263a-dev-2f08980441f26b55db4d95db8ee42c958882cc36
On the github issue tracking it seems to fix the issue, it’s a small workaround before they fix it.
It seems to work on my side without downgrading drivers.
Thanks.
Cany any please post a little HowTo for Debian 10? Im no Profi, i use a Intel 8700.
(1:79)# apt install beignet-opencl-icd
Reading package lists... Done
Building dependency tree
Reading state information... Done
beignet-opencl-icd is already the newest version (1.3.2-6+b10).
