HDR Tonemapping with Hardware Transcoding Broken PMS 1.29.2.6364
How can I modify the XML file to remove subtitles?
You REMUX the file (mkvtoolnix is a good tool – you unselect the PGS tracks – and create a new output file)
Save the old file.
Put the new file in its place.
Tell PMS to “Analyze” the file movie again.
Check the XML and the PGS will be gone.
Now you can test.
Thanks managed to remove the subtitles as confirmed by viewing the XML data, however the same crash/stall occurs. Here are the logs
Plex Media Server Logs_2023-05-07_16-03-38.zip (1.3 MB)
@andrew_sou
Try using Plex/web and on the same account.
The android playback has a separate problem. (does the player app settings allow transcoding and direct streaming?)
May 07, 2023 16:03:32.873 [0x80bcb3500] WARN - [Req#37a/Transcode] Denying access due to session lacking permission to transcode key /library/metadata/831
May 07, 2023 16:03:32.873 [0x806a15100] DEBUG - Completed: [10.0.0.11:38598] 400 GET /video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=20000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F831&protocol=hls&session=af20242abbf76dbb-com-plexapp-android&subtitleSize=100&videoBitrate=20000&videoQuality=100&videoResolution=3840x2160 (29 live) #37a TLS GZIP 8ms 429 bytes (pipelined: 5)
May 07, 2023 16:03:33.885 [0x80bcb3500] DEBUG - Request: [10.0.0.11:38598 (WAN)] GET /video/:/transcode/universal/start.m3u8
@ChuckPa I’m pleased to say that hw transcoding appears to be somewhat working after the recent 1.32.2.7002 beta update, despite in the release notes it mentioning “(Transcoder) Removed support for Intel hardware transcoding on FreeBSD (#14281)” as a Feature?
However the stream seams to crash when transcoding HDR content, regardless of playback device/method (iPad w/ Plex 8.19 or Plex Web via Brave).
Attached are the logs if you wish to look into it.
Thanks for your time so far mate.
Plex Media Server Logs_2023-05-11_21-34-17.zip (1.6 MB)
This is still an iOS problem.
May 11, 2023 21:33:20.261 [0x809df7b00] DEBUG - [Req#210b] [Now] User is andrew.sou (ID: 1)
May 11, 2023 21:33:20.262 [0x809df7b00] DEBUG - [Req#210b] [Now] Device is iOS (iPad).
May 11, 2023 21:33:20.262 [0x809df7b00] DEBUG - [Req#210b] [Now] Profile is iOS
May 11, 2023 21:33:20.262 [0x809df7b00] DEBUG - [Req#210b] [Now] Updated play state for /library/metadata/831.
using augmented profile iOS
It’s DirectStreaming (Remux for iOS – normal behavior)
Then it closes and fails.
May 11, 2023 21:34:13.700 [0x80cca9000] DEBUG - [Req#219e] [com.plexapp.system] HTTP reply status 200, with 418 bytes of content.
May 11, 2023 21:34:13.700 [0x806a15100] DEBUG - Completed: [192.168.1.12:57277] 200 GET /system/:/prefs (26 live) #219e TLS GZIP 6ms 734 bytes (pipelined: 305)
May 11, 2023 21:34:13.711 [0x806a15800] DEBUG - CERT: incomplete TLS handshake from 192.168.1.12:57378: sslv3 alert certificate unknown (SSL routines)
May 11, 2023 21:34:13.726 [0x80cca9000] DEBUG - Request: [192.168.1.12:57379 (Subnet)] GET /:/websockets/notifications?filters=log (28 live) #21a9 TLS GZIP Signed-in Token (andrew.sou) (Chrome)
May 11, 2023 21:34:13.726 [0x80cca9000] DEBUG - WebSocket: Performing handshake from origin https://192.168.1.61:32400
May 11, 2023 21:34:13.726 [0x80cca9000] DEBUG - Beginning read from WebSocket
May 11, 2023 21:34:13.768 [0x80cca9000] DEBUG - Request: [192.168.1.12:57277 (Subnet)] GET /activities (28 live) #21a8 TLS GZIP Signed-in Token (andrew.sou) (Chrome)
May 11, 2023 21:34:13.769 [0x806a15800] DEBUG - Completed: [192.168.1.12:57277] 200 GET /activities (28 live) #21a8 TLS GZIP 0ms 350 bytes (pipelined: 306)
May 11, 2023 21:34:14.114 [0x806a15100] DEBUG - WebSocket: client initiated close
May 11, 2023 21:34:14.114 [0x806a15100] DEBUG - NotificationStream: Removing because of close
When this happens can you take a screenshot ? That should initiate a ‘feedback’ to the devs which sends the player logs captured at that moment.
It seems they got most of the issues but not all of them as this looks like a player app crash ? :frowning:
Installed 1.32.2.7100 with Docker on Ubuntu. HW HDR Tone mapping is working for me now.
I migrated my TrueNAS Core install to TrueNAS Scale and setup Plex using the built in Apps Catalogue. HW transcoding is working as expected and I’m happy that I’m getting the benefits of my Plex Pass. Thank you to @ChuckPa for all your time spent digging through this.
To clarify my post from yesterday. I did not change anything except upgrading the Plex container for HDR to work. My Plex (along with many other containers) has been on the same Intel NUC with Ubuntu for the entire time.
