Repeat poster still trying to get the plugin to work on Ubuntu 12.04 with PMS 0.9.8.14. It looks like everything is running but the channel does not work in Plex Web.
Enter the following info into the Plex HD Surfer v0.5 plug-in preferences:
Stream Server IP: 192.168.2.123
Stream Server Port: 23013
Communication Port: 8000
HDHomeRun ID: 1318CA42 [FOUND: 192.168.2.216]
HDHomeRun Tuner: 0
HDSurferWave ALPHA-0.3 is now up and running!
From the HDSurferWave.log:
2013-12-14 09:51:26,180 (7fb2eea2e700) : INFO (core:336) - Starting framework core - Version: 2.3.12, Build: bd749cb (Mon Nov 18 18:57:02 UTC 2013)
2013-12-14 09:51:26,180 (7fb2eea2e700) : DEBUG (core:348) - Using the standard policy
2013-12-14 09:51:26,181 (7fb2eea2e700) : DEBUG (core:437) - Starting runtime component.
2013-12-14 09:51:26,183 (7fb2eea2e700) : DEBUG (core:437) - Starting caching component.
2013-12-14 09:51:26,184 (7fb2eea2e700) : DEBUG (core:437) - Starting data component.
2013-12-14 09:51:26,184 (7fb2eea2e700) : DEBUG (core:437) - Starting networking component.
2013-12-14 09:51:26,185 (7fb2eea2e700) : DEBUG (networking:318) - Loaded HTTP cookies
2013-12-14 09:51:26,186 (7fb2eea2e700) : DEBUG (networking:504) - Setting the default network timeout to 20.0
2013-12-14 09:51:26,188 (7fb2eea2e700) : DEBUG (core:437) - Starting localization component.
2013-12-14 09:51:26,188 (7fb2eea2e700) : INFO (localization:408) - Setting the default locale to en-us
2013-12-14 09:51:26,188 (7fb2eea2e700) : DEBUG (core:437) - Starting messaging component.
2013-12-14 09:51:26,189 (7fb2eea2e700) : DEBUG (core:437) - Starting debugging component.
2013-12-14 09:51:26,190 (7fb2eea2e700) : DEBUG (core:437) - Starting services component.
2013-12-14 09:51:26,190 (7fb2eea2e700) : DEBUG (core:437) - Starting myplex component.
2013-12-14 09:51:26,191 (7fb2ceffd700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.hdsurfer'
2013-12-14 09:51:26,191 (7fb2eea2e700) : DEBUG (core:437) - Starting notifications component.
2013-12-14 09:51:26,342 (7fb2eea2e700) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.hdsurfer in namespace 'metadata'
2013-12-14 09:51:26,346 (7fb2eea2e700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2013-12-14 09:51:26,629 (7fb2ceffd700) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2013-12-14 09:51:26,629 (7fb2eea2e700) : DEBUG (runtime:1107) - Created a thread named 'load_all_services'
2013-12-14 09:51:26,631 (7fb2ceffd700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMAp$
2013-12-14 09:51:26,632 (7fb2eea2e700) : DEBUG (runtime:1107) - Created a thread named 'get_server_info'
2013-12-14 09:51:26,632 (7fb2eea2e700) : DEBUG (core:149) - Finished starting framework core
2013-12-14 09:51:26,632 (7fb2cdffb700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400'
2013-12-14 09:51:26,633 (7fb2eea2e700) : DEBUG (core:547) - Loading plug-in code
2013-12-14 09:51:26,689 (7fb2eea2e700) : DEBUG (core:553) - Finished loading plug-in code
2013-12-14 09:51:26,689 (7fb2eea2e700) : DEBUG (runtime:640) - Adding a prefix handler for 'HD Surfer' ('/video/hdsurfer')
2013-12-14 09:51:26,694 (7fb2eea2e700) : INFO (__init__:11) - ***HD Surfer has run start()***
2013-12-14 09:51:26,694 (7fb2eea2e700) : INFO (core:598) - Started plug-in
2013-12-14 09:51:26,694 (7fb2eea2e700) : DEBUG (socketinterface:144) - Starting socket server
2013-12-14 09:51:26,696 (7fb2eea2e700) : DEBUG (runtime:1107) - Created a thread named 'start'
2013-12-14 09:51:26,696 (7fb2eea2e700) : INFO (socketinterface:168) - Socket server started on port 43952
2013-12-14 09:51:26,696 (7fb2eea2e700) : INFO (pipeinterface:25) - Entering run loop
2013-12-14 09:51:26,697 (7fb2eea2e700) : DEBUG (runtime:717) - Handling request GET /:/prefixes
2013-12-14 09:51:26,699 (7fb2eea2e700) : DEBUG (runtime:814) - Found route matching /:/prefixes
2013-12-14 09:51:26,702 (7fb2cdffb700) : DEBUG (core:525) - Machine identifier is 56d344286fdb5f5c1ad99e0cfb7b42c195e0976a
2013-12-14 09:51:26,702 (7fb2cdffb700) : DEBUG (core:526) - Server version is 0.9.8.14.263-139ddbc
2013-12-14 09:51:26,787 (7fb2ceffd700) : DEBUG (services:362) - Loaded services
2013-12-14 09:51:26,796 (7fb2ce7fc700) : DEBUG (services:438) - No shared code to load
2013-12-14 09:51:26,798 (7fb2eea2e700) : DEBUG (runtime:914) - Response: [200] MediaContainer, 449 bytes
2013-12-14 09:51:26,845 (7fb2ce7fc700) : DEBUG (runtime:717) - Handling request GET /video/hdsurfer
2013-12-14 09:51:26,851 (7fb2ce7fc700) : DEBUG (runtime:814) - Found route matching /video/hdsurfer
2013-12-14 09:51:26,852 (7fb2ce7fc700) : DEBUG (preferences:256) - Loaded preferences from DefaultPrefs.json
2013-12-14 09:51:26,853 (7fb2ce7fc700) : DEBUG (preferences:178) - Loaded the user preferences for com.plexapp.plugins.hdsurfer
2013-12-14 09:51:46,874 (7fb2ce7fc700) : INFO (__init__:23) - Checking to make sure the XMLRPC server is running...failed!
2013-12-14 09:51:46,875 (7fb2ce7fc700) : DEBUG (base:123) - Checking if com.plexapp.plugins.hdsurfer is broken
2013-12-14 09:51:46,876 (7fb2ce7fc700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3Q$
2013-12-14 09:51:46,890 (7fb2ce7fc700) : DEBUG (runtime:106) - Sending packed state data (109 bytes)
2013-12-14 09:51:46,890 (7fb2ce7fc700) : DEBUG (runtime:914) - Response: [200] MediaContainer, 599 bytes
The key thing I see there is the XMLRPC server running check failed. Any ideas or tips to try next?
