Same for me. v8.14 seems to have fixed this issue on my 2017 Apple TV 4K.
My settings are…
Direct Play = ON
Use Old Player = NO
Automatically adjust quality = OFF
And now Dolby Vision content is Direct Playing again (and only Direct Streamed when the audio is TrueHD, which I think was always the case previously). Either way, the video seems to be fixed for both Direct Play and Direct Stream. Hurrah!
However, now that 4K DV video is buttery smooth again, it’s very apparent that the audio is out of sync!
It appears to be ever so slightly ahead of the video. For testing, I’m using a scene where a character slaps another character across the face.
It’s worse for TrueHD audio but it’s also apparent on AC3 and DTS. I don’t see this problem with non-Dolby Vision content or with HD rips
My 4K DV library consists of my own UHD collection which I have ripped to MKV using the current version of MakeMKV.
According to mediainfo, they are all either…
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
or
Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Didn’t the Plex app used to have a setting to adjust the sync by a certain number of frames in each direction? Or did I imagine that? Maybe you could add that to the pull down options when a video is playing.
I hate to say it, but Infuse plays all these files in Direct Play mode, supports TrueHD audio, and the audio perfectly in sync across all formats.
But is Infuse playing it in Dolby Vision? I don’t know, because my LG OLED only says “HDR” in the corner when the playback starts, yet when I start it in Plex it says “Dolby Vision” – although from what I’ve read above, it seems that Plex is faking it somehow? Some clarification on this would be great!
