Held transaction for too long (../Statistics/StatisticsManager.cpp:253)
  1. I disabled all automatic media scans, still get those messages all the time.
  2. the system is under load every 30 sec for 10 sec when there is NOTHING going on, no scan running, no playback, nothing. It affects 1 CPU Thread then. From what I see Plex only uses one, so during that times the server acts very slow if I have a playback request. This is happening now with the most recent version.
We need to peel this down a layer or two because I’m running on Fedora and QNAP but can’t replicate it.
What are the host OS’s these systems are running on?
Are any of the docker containers, or the metadata (/config) diretories, stored across the network?
@ChuckPa I’m on Fedora 30 as well. Metadata hosted locally same server.
Oct 02, 2019 22:26:03.931	WARN	Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 1.370000 seconds
Oct 02, 2019 22:25:32.821	WARN	Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 0.110000 seconds
Oct 02, 2019 22:25:32.746	WARN	Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 1.240000 seconds
Oct 02, 2019 22:25:01.546	WARN	Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 1.250000 seconds
Oct 02, 2019 22:24:30.360	WARN	Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 1.320000 seconds
Is the above ‘filtered’ with grep or is that all which existing in the logs?
Without knowing what PMS is doing when those occur, (forgive the metaphor) it’s like looking for a leak without lights.
If filtered, may I have the ZIP file please which captures these?
Does the PMS have DVR configured?
For me it’s running on Ubuntu 18.04-2, no Docker or other virtualisation layer. The system specs are above. System (and also the database) is installed on a SSD, the actual data is on huge rotating disks on the same server.
Oct 03, 2019 07:06:16.091 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.380000 seconds
Oct 03, 2019 07:06:16.723 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:06:17.370 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:06:18.001 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:06:18.641 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:06:19.292 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:19.941 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:06:20.911 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.550000 seconds
Oct 03, 2019 07:06:21.580 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:06:22.211 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:22.848 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:06:23.495 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:24.145 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:24.794 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:06:25.461 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:06:26.108 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:26.756 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:06:27.624 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.540000 seconds
Oct 03, 2019 07:06:28.402 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:06:29.038 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:06:29.040 [0x7f57faffd700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.850000 seconds
Oct 03, 2019 07:06:59.701 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:00.339 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:00.969 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:01.605 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:02.257 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:02.905 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:03.572 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:04.391 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.490000 seconds
Oct 03, 2019 07:07:05.214 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:05.843 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:06.472 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:07.124 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:07.773 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:08.421 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:09.069 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:09.718 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:10.373 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:11.026 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:12.044 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.410000 seconds
Oct 03, 2019 07:07:12.680 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:12.682 [0x7f5815ffb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.620000 seconds
Oct 03, 2019 07:07:43.538 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:07:44.166 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.300000 seconds
Oct 03, 2019 07:07:44.794 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:45.426 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:46.067 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:46.734 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:07:47.380 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:48.029 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:49.031 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.500000 seconds
Oct 03, 2019 07:07:49.661 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:50.289 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:50.925 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:51.570 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:52.218 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:52.867 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:07:53.518 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:54.169 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:07:54.836 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:07:55.741 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.590000 seconds
Oct 03, 2019 07:07:56.472 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:07:56.475 [0x7f58437fe700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.790000 seconds
Oct 03, 2019 07:08:27.503 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.420000 seconds
Oct 03, 2019 07:08:28.159 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:08:28.792 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:29.421 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:30.058 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:30.704 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:31.351 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:32.000 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:32.766 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.450000 seconds
Oct 03, 2019 07:08:33.651 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:08:34.278 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:34.918 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:35.561 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:36.226 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:36.873 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:37.523 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:38.174 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:38.824 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:08:39.472 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:08:40.471 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.450000 seconds
Oct 03, 2019 07:08:40.473 [0x7f57f3fff700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.980000 seconds
Oct 03, 2019 07:09:11.501 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.440000 seconds
Oct 03, 2019 07:09:12.143 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:12.783 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:13.413 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.300000 seconds
Oct 03, 2019 07:09:14.052 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:14.796 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:15.462 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:16.109 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:16.759 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:17.755 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.510000 seconds
Oct 03, 2019 07:09:18.396 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:19.034 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:09:19.670 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:20.320 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:20.981 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:21.629 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:22.276 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:22.931 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:09:23.599 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:24.513 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.560000 seconds
Oct 03, 2019 07:09:24.517 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 14.030000 seconds
Oct 03, 2019 07:09:55.180 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:09:55.810 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:09:56.444 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:57.080 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:57.725 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:09:58.371 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:59.024 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:09:59.678 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:00.326 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:01.149 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.490000 seconds
Oct 03, 2019 07:10:01.976 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:02.641 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:03.274 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:03.923 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:04.572 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:05.231 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:05.883 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:06.531 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:07.185 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:07.895 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.390000 seconds
Oct 03, 2019 07:10:07.899 [0x7f57fb7fe700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.370000 seconds
Oct 03, 2019 07:10:38.563 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:39.206 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:39.835 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.300000 seconds
Oct 03, 2019 07:10:40.467 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:10:41.111 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:41.763 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:42.411 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:43.060 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:43.708 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:44.378 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.350000 seconds
Oct 03, 2019 07:10:45.377 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.430000 seconds
Oct 03, 2019 07:10:46.009 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:46.640 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:47.294 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:47.945 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:48.596 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:49.244 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:49.893 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:50.548 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:10:51.202 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:10:51.204 [0x7f58777fe700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.290000 seconds
Oct 03, 2019 07:11:21.937 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:11:22.568 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:23.199 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:11:23.831 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:11:24.480 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:11:25.125 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:11:25.771 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:26.420 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:27.070 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:27.717 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:28.626 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.570000 seconds
Oct 03, 2019 07:11:29.361 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:11:29.992 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:11:30.633 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:31.280 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:31.928 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:32.577 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:11:33.227 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:33.875 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:11:34.524 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:11:34.527 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.310000 seconds
Oct 03, 2019 07:12:05.335 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.460000 seconds
Oct 03, 2019 07:12:06.145 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:06.774 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:12:07.409 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:08.044 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:08.695 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:09.369 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:12:10.014 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:10.664 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:11.313 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:11.968 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:12.969 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.460000 seconds
Oct 03, 2019 07:12:13.600 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:14.229 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:12:14.872 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:12:15.519 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:16.168 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:16.826 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:17.500 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:18.152 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:18.155 [0x7f57f9ffb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.610000 seconds
Oct 03, 2019 07:12:48.816 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:49.815 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.480000 seconds
Oct 03, 2019 07:12:50.444 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:51.075 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:51.710 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:52.354 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:53.020 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:53.667 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:54.316 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:54.964 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:55.611 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:56.542 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.580000 seconds
Oct 03, 2019 07:12:57.255 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:12:57.885 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.310000 seconds
Oct 03, 2019 07:12:58.517 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.320000 seconds
Oct 03, 2019 07:12:59.164 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:12:59.814 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:13:00.464 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:13:01.134 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.330000 seconds
Oct 03, 2019 07:13:01.782 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.340000 seconds
Oct 03, 2019 07:13:01.785 [0x7f57f1ffb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:252): 13.620000 seconds
Thats the last part of my plex server log as there is nothing connected to the server.
as you see above you get this warnings for a given time (13 sec in my case) and then it makes a 30 sec break and starts all over
7:06:16 - 7:06:29
7:06:59 - 7:07:12
7:07:43 - 7:07:56
The above log part is not filtered. There is nothing else going on on the server because no client connected.
If you need more data let me know. I just try to avoid to send whole logfiles to this thread because I don’t know what kind of personal data is stored in there.
Windows, no docker, no config/etc on network drives. Everything plex related on SSD except data on spinning disks. No DVR
I just installed the update to 1.17.0.1841 and it seems the issue is gone.:+1:
I’m on 1.18 and I still got it 🤷
I’m on 1.18.0.1846 and also getting this warning constantly.
Found this thread when searching for errors that appear in my server logs. Get a short burst of activity every 30s that causes 1 core to go to 100% utilization and then right back down. Repeats itself in perpetuity. I’m running 1.18.0.1913 on Windows 10 (just upgraded to this version so am waiting to see if this issue surfaces again after a restart). This happens while the system is otherwise completely idle.
Oct 09, 2019 21:50:27.861 [2452] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:50:28.736 [2452] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:50:29.611 [2452] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:50:30.486 [2452] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:50:30.486 [2452] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.500000 seconds
Oct 09, 2019 21:51:01.361 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:02.236 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:03.111 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.421875 seconds
Oct 09, 2019 21:51:03.986 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:03.986 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.484375 seconds
Oct 09, 2019 21:51:34.861 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.421875 seconds
Oct 09, 2019 21:51:35.736 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:36.627 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:37.502 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:51:37.502 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.515625 seconds
Oct 09, 2019 21:52:08.377 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:09.252 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:10.127 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:11.002 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:11.002 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.484375 seconds
Oct 09, 2019 21:52:41.892 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:42.783 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:43.658 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:44.533 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:52:44.533 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.515625 seconds
Oct 09, 2019 21:53:15.408 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:16.283 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:17.158 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:18.033 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:18.033 [7620] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.500000 seconds
Oct 09, 2019 21:53:48.908 [3532] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.421875 seconds
Oct 09, 2019 21:53:49.783 [3532] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:50.658 [3532] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:51.549 [3532] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:53:51.549 [3532] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.500000 seconds
Oct 09, 2019 21:54:22.455 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.453125 seconds
Oct 09, 2019 21:54:23.330 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:54:24.205 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.437500 seconds
Oct 09, 2019 21:54:25.080 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsMedia.cpp:29): 0.421875 seconds
Oct 09, 2019 21:54:25.095 [0224] WARN - Held transaction for too long (..\Statistics\StatisticsManager.cpp:252): 3.515625 seconds
Thats exactly what I described earlier. For me this was gone with 1.17.0.1841 (I’m on public updates). Seems they fixed this in public version but not in beta yet.
running plex 1.18.0.1944 on a naked Ubuntu 18.04.3
I´ve got the same error as above mentioned and couple of others.
ERROR - [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
ERROR - [FFMPEG] - libva: va_getDriverName() failed with unknown libva error,driver_name=(null)
ERROR - [Transcoder] [h264 @ 0x3d9ac80] mmco: unref short failure
I´ve attached the logs from today. I have the database optimization scheduled as it should. My Database is about 300 MB with an total count of 175975 items (files on filesystem)
Plex Media Server.log (247.1 KB)
Been seeing this for a while now too. Not sure when it started but it has persisted through the last several releases.
CentOS7, fully updated. Current Plex Server Public version. (I should note, this is not a docker install, this is running straight on the machine.)
Database is 211mb, system is a Core i5 4th gen and Plex is running from an SSD. This system is blazing fast, so something seems to be wrong with what Plex is doing here.
I have ran the database check and no issues were found or anything weird like that. Dumping and re-importing only changes the database size by a couple megabytes.
Plex was idle here. Scheduled tasks done, and no one was watching anything. The log is PACKED with this…
Oct 18, 2019 05:26:47.516 [0x7f55927f4700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:28:47.956 [0x7f56165dc700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:31:48.634 [0x7f55d6ffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:34:49.217 [0x7f5615ddb700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:36:19.519 [0x7f56175de700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:37:49.826 [0x7f5591677700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 05:38:50.051 [0x7f56254ab700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:39:20.173 [0x7f5615ddb700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:41:20.603 [0x7f560dffb700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:44:51.336 [0x7f5624caa700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:45:06.343 [0x7f5590675700] INFO - AutoUpdate: no updates available
Oct 18, 2019 05:45:21.450 [0x7f55ba7fc700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:46:51.827 [0x7f559f7fe700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 05:47:52.068 [0x7f560dffb700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:49:52.471 [0x7f5592ff5700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:50:22.595 [0x7f55d6ffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:52:23.007 [0x7f5591677700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:55:23.619 [0x7f55d6ffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:56:23.804 [0x7f56175de700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:56:53.930 [0x7f560f7fe700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 05:57:24.047 [0x7f55927f4700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 05:58:24.287 [0x7f558e7ec700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 06:01:55.027 [0x7f560effd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:03:55.495 [0x7f56175de700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 06:04:55.727 [0x7f55d6ffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:09:26.686 [0x7f558d7ea700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:10:57.015 [0x7f560effd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:11:32.159 [0x7f56165dc700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Oct 18, 2019 06:12:27.266 [0x7f55baffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:12:57.385 [0x7f5592ff5700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:13:27.507 [0x7f560effd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:14:27.725 [0x7f560ffff700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:16:28.153 [0x7f560dffb700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:16:58.271 [0x7f55baffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:19:58.889 [0x7f55947f8700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 06:21:29.236 [0x7f55947f8700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Oct 18, 2019 06:21:59.361 [0x7f55baffd700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.120000 seconds
Oct 18, 2019 06:22:29.478 [0x7f56175de700] WARN - Held transaction for too long (…/Statistics/StatisticsManager.cpp:248): 0.110000 seconds
Hello I have the same error now.
Has anybody an idea whats going on?
Pley was running fine since 2017 on this machine.
The Database is located on an SSD.
I have a lot of pictures and music. My Database is 401 MB
Server Version#: 1.18.1.1973 on docker
Player Version#: 4.10.1
Since last update I get a lot of this warnings:
Copy to clipboard
Oct 29, 2019 07:12:36.822 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:36.884 [0x7f665e7fc700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:37.243 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.200000 seconds
Oct 29, 2019 07:12:37.665 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:37.989 [0x7f65fbfff700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:38.083 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:38.505 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:38.924 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:39.103 [0x7f665e7fc700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:39.341 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:39.766 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.200000 seconds
Oct 29, 2019 07:12:40.208 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.230000 seconds
Oct 29, 2019 07:12:40.209 [0x7f65fbfff700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:40.639 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.220000 seconds
Oct 29, 2019 07:12:41.064 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:41.325 [0x7f665e7fc700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:41.495 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.220000 seconds
Oct 29, 2019 07:12:41.931 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.220000 seconds
Oct 29, 2019 07:12:42.355 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:42.431 [0x7f65fbfff700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:42.783 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.220000 seconds
Oct 29, 2019 07:12:43.205 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.220000 seconds
Oct 29, 2019 07:12:43.545 [0x7f665e7fc700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:43.635 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:44.060 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:44.493 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.230000 seconds
Oct 29, 2019 07:12:44.653 [0x7f65fbfff700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:44.943 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.230000 seconds
Oct 29, 2019 07:12:45.381 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:45.766 [0x7f665e7fc700] Warnung — Waited one whole second for a busy database.
Oct 29, 2019 07:12:45.804 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.210000 seconds
Oct 29, 2019 07:12:46.224 [0x7f66eb7fe700] Warnung — Held transaction for too long (../Statistics/StatisticsMedia.cpp:29): 0.200000 seconds
Here is a statistic of my libraries:
Stefan Archiv Serien Show	38	52	275
Musik Artist	1305	3779	29460
Allgemein TV-Serien Show	68	82	281
Allgemein Filme Movie	70
Emil Archiv Serien Show	7	16	91
Emil VDR1 Movie	344
Sandra Archiv Serien Show	7	12	53
Stefan VDR1 Movie	26
Emil Archiv Filme Movie	43
Sandra Filme VDR1 Movie	175
Fotos Photo	67	23126	689
Sandra Archiv Filme Movie	6
Stefan Archiv Filme Movie	36
Musikfilme Movie	46
Fotos Josef Photo	39	38	1
Best regards,
Stefan
I guess I’m stuck with this same issue. I’m going to downgrade to 1.14 until I see some solution here. Really unfortunate…
Nov 02, 2019 22:18:57.588 [0x7f7ea4e31700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:19:27.679 [0x7f7ea4e31700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:19:57.768 [0x7f7ea7fff700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:20:27.894 [0x7f7ea4e31700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:20:57.982 [0x7f7ee58cb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.170000 seconds
Nov 02, 2019 22:21:28.068 [0x7f7ee6771700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.170000 seconds
Nov 02, 2019 22:21:58.164 [0x7f7ee55dd700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.200000 seconds
Nov 02, 2019 22:22:28.253 [0x7f7ea59e9700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:22:58.351 [0x7f7ea59e9700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.210000 seconds
Nov 02, 2019 22:23:28.452 [0x7f7ee6771700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.170000 seconds
Nov 02, 2019 22:23:58.549 [0x7f7ee451f700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.200000 seconds
Nov 02, 2019 22:24:28.634 [0x7f7ee58cb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.200000 seconds
Nov 02, 2019 22:24:58.767 [0x7f7ee6195700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.210000 seconds
Nov 02, 2019 22:25:28.848 [0x7f7ee5bb9700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.150000 seconds
Nov 02, 2019 22:25:58.948 [0x7f7ee744e700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.200000 seconds
Nov 02, 2019 22:26:29.026 [0x7f7ee744e700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.170000 seconds
Nov 02, 2019 22:26:59.113 [0x7f7ee4afb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:27:29.186 [0x7f7ee58cb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.160000 seconds
Nov 02, 2019 22:27:59.267 [0x7f7ee4afb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.160000 seconds
Nov 02, 2019 22:28:11.380 [0x7f7ea4855700] INFO - AutoUpdate: no updates available
Nov 02, 2019 22:28:28.626 [0x7f7ea56fb700] INFO - AutoUpdate: no updates available
Nov 02, 2019 22:28:29.358 [0x7f7ea59e9700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:28:30.145 [0x7f7ea7447700] WARN - QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Nov 02, 2019 22:28:30.158 [0x7f7ea7447700] WARN - QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Nov 02, 2019 22:28:30.264 [0x7f7ea7447700] WARN - SLOW QUERY: It took 220.000000 ms to retrieve 50 items.
Nov 02, 2019 22:28:30.469 [0x7f7ea7447700] WARN - SLOW QUERY: It took 240.000000 ms to retrieve 41 items.
Nov 02, 2019 22:28:31.830 [0x7f7ea56fb700] INFO - AutoUpdate: no updates available
Nov 02, 2019 22:28:59.488 [0x7f7ee6e72700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.170000 seconds
Nov 02, 2019 22:29:08.379 [0x7f7ea4855700] WARN - SLOW QUERY: It took 230.000000 ms to retrieve 50 items.
Nov 02, 2019 22:29:29.579 [0x7f7ea7fff700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.180000 seconds
Nov 02, 2019 22:29:59.664 [0x7f7ee480d700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:30:29.748 [0x7f7ea4e31700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:30:59.835 [0x7f7ea7fff700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.210000 seconds
Nov 02, 2019 22:31:29.931 [0x7f7ea4567700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.200000 seconds
Nov 02, 2019 22:32:00.031 [0x7f7ee7d18700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.210000 seconds
Nov 02, 2019 22:32:30.118 [0x7f7ee480d700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:33:00.200 [0x7f7ee5bb9700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:33:30.287 [0x7f7ea4567700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.190000 seconds
Nov 02, 2019 22:34:00.382 [0x7f7ee58cb700] WARN - Held transaction for too long (../Statistics/StatisticsManager.cpp:248): 0.210000 seconds
Just chiming in here as I am seeing the same. PMS version 1.18.1.1973 running on FreeBSD 11.2-STABLE.
Hi.
Same issue for me. I’m using Unraid >
I noticed every 20 seconds or so, a single core will spike to 100% for a few seconds. the log shows the same as everyone elses.
1.18.1.1973
Same here on windows.
Getting >1000 of these every 5 minutes
Same problem, for quite some time (weeks at least). I’ve had to restart the service periodically when I noticed a playback client hung for long periods and then see it running with one CPU core pegged 100%. Try explaining that to a 6 yr old who just wants his Cars movie.
host:/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs$ grep “sticsMedia.cpp:29” *.log | wc -l
198072
This is from the last 7 days, nearly 200K entries for a statistics error? How do I just turn off statistics, they aren’t for me, I don’t care or want them. Server is the latest stable version, 1.18.1.1973.
The machine is a dedicated Linux server, not running in a docker container, E3-1270 @ 3.6Ghz, 64GB of memory, running on an NVMe SSD. The collection is small and the only users are my family (of 3). No DVR usage. Database is set to optimize weekly, and machine is a 24/7 file server, so always on. Yes Houston, we have a problem.
I was also experiencing this problem in Plex 1.16.3.1402 on FreeNAS. A database repair appears to have corrected this issue for now. I followed the instructions for Linux and it worked exactly the same, though I did hit a couple of minor snags with the sqlite commands.
EDIT: I had go through all of these steps again today (12/23/19) for the same issue. I guess this is something I’m just going to need to do as necessary until a bug fix is released.
:confounded:
