Help building Plex Home Theater
Or is it a bug?
Hi!
I installed the latest Arch Linux i686 and did a git clone from:
https://github.com/plexinc/plex-home-theater-public/
After resolving all the dependencies, the build went fine; no errors. But, if I want to run it, I got:
Unable to find path to XBMC data files!<br />
Exiting Plex Media Server queue...<br />
*** Error in `./plexhometheater': free(): invalid pointer: 0x09573400 ***<br />
======= Backtrace: =========<br />
/usr/lib/libc.so.6(+0x764b2)[0xb58154b2]<br />
/usr/lib/libc.so.6(+0x77200)[0xb5816200]<br />
/usr/lib/libpthread.so.0(+0x6af6)[0xb64d1af6]<br />
/usr/lib/libpthread.so.0(+0x6d16)[0xb64d1d16]<br />
/usr/lib/libc.so.6(clone+0x5e)[0xb588fcce]<br />
======= Memory map: ========<br />
[Snipped memory dump]<br />
I configured with:
./configure --prefix=/usr --with-platform=linux --disable-webserver --enable-libcec
Can someone help me resolving this issue?
Thanks in advance,
zAo | Johan
Hi.
EDIT: Find the fix…
<br />
$export XBMC_HOME=/usr/share/XBMC<br />
$plexhometheater<br />
found it here: http://forums.plexapp.com/index.php/topic/58625-gentoo-from-git-sources-pht-status/page__view__findpost__p__347113
I've got the same error on both my htpc and my thinkpad both are x86_64 builds
<br />
*** Error in `plexhometheater': free(): invalid pointer: 0x00000000010ab9d0 ***<br />
/usr/lib/libc.so.6(+0x7ab06)[0x7fc401464b06]<br />
/usr/lib/libc.so.6(+0x7b883)[0x7fc401465883]<br />
/usr/lib/libpthread.so.0(+0x7bd2)[0x7fc405f39bd2]<br />
/usr/lib/libpthread.so.0(+0x7e1d)[0x7fc405f39e1d]<br />
/usr/lib/libc.so.6(clone+0x6d)[0x7fc4014d2efd]<br />
--SNIP--<br />
Regards.
Thanks rZn!
I currently get an error on libavformat.so.54, but I’m one step further now. Thanks!
You can’t use the automake buildsystem for PLEX/ht:
mkdir build; cd build
cmake … ; make
Should get you started
You can't use the automake buildsystem for PLEX/ht:
cmake .. ; make
Is this always going to be the case. A few weeks ago I attempted to use the buildroot for the pivos xios ds provided here https://github.com/Pivosgroup. Which I pointed to plex ht but ran into countless issues when it started to build plex. It seems you guys have moved onto cmake and left make in the dust.
I would never use automake. But cmake can generate makefiles.
