hello, i lost my code ping helpme plz
Hello Chris and welcome to the Plex forums,
What code are you referring to? If you mean your password, you can use the “forgot password” link on the sign up page. If you mean your 4-digit PIN, log into your account on plex.tv, then go to your user profile. You can change or remove your PIN there.
