Just found that my ISP not only pass to ipv6 but also change for CGNAT scenario
Is there a way to bypass this so i can have remote access to the server?
System Info:
CPU: i5 3330 @ 3.0 GHz
Memory 8 Gb DDR3 Dual Channel @ 1333
Primary storage: Kingston 120 Gb SSD (OS in Same SSD of Plex Server)
Windows 10 Pro Build 1803
Plex-Media-Server-1.13.1.5063-b4605f76e (Plex Pass)
Modem: Technicolor TC7300b
IP in router: 100.100 type
seems that public ip is shared!?
My ISP upgraded their network recently, and it included a NAT addon. They mentioned to me, after I noticed this feature enabled via the remote server settings of Plex, that it is optional to change my ‘standard IP’ to a ‘dynamic IP’ in the login settings of their website. ISPs should really be giving people an option as to if they want the NAT/CGNAT enabled on their end or not.
“They mentioned to me, after I noticed this feature enabled via the remote server settings of Plex”
How can you check this? and are you in Brazil? If yes wich ISP?
