Hi Guys!
I have one file that has 02 TV Episodes in a row. Is there a way to named this files so plex can “see” this and Split it so i can have that displayed in my episodes list info.
Thanks!
Braz.
Hi Guys!
Thanks!
Braz.
You can use a naming convention like S01E01E02 which would indicate SEASON 1 and both episodes 01 & 02.
Personally I don’t like having missing episode numbers in Plex when viewing libraries so I will manually split the file into the two parts. It’s a manual process but I prefer the outcome much better.
Lots of free tools you can use to cut/save files such as Avidemux which works with MKV, AVI, MP4, TS and other files.
Carlo
@cayars said:
You can use a naming convention like S01E01E02 which would indicate SEASON 1 and both episodes 01 & 02.Personally I don’t like having missing episode numbers in Plex when viewing libraries so I will manually split the file into the two parts. It’s a manual process but I prefer the outcome much better.
Carlo
Hi @cayars!
Thank you for your help! This is a solution but i want to avoid it. It seems to me that the link below posted by @OttoKerner is a reasonable solution for this case.
Thank you again for your help!
Braz.
The problem is that if you don’t split the files then if you use any tools to look for missing episodes these multi-episodes will come up missing the second file. In Plex you will also have an episode “missing” from the listings.
So with something like S01E01E02 you’ll end up with a listing for E01 then nothing for E02 and then a listing for E03. So it “looks” like you have missing media.
How many files do you have like this? If only a couple a tools like AVIdemux (windows) would make short order of splitting the files.
Hope that’s clear and simple enough.
Best of luck to you however you accomplish this,
Carlo
Thank you for your reply @cayars !
I only have 02 or 03 files like this…I will give i try on this method…Believe me i am not good with these tools but it seems to be an easy thing to do.
Thank you!
Braz.
Here’s another option
https://forums.plex.tv/discussion/173648/howto-splitting-multi-episode-files-with-mkvtoolnix-gui/p1#top
@OttoKerner said:
@BrazMan said:
I only have 02 or 03 files like this…I will give i try on this method…Believe me i am not good with these tools but it seems to be an easy thing to do.Here’s another option
THX @OttoKerner . I will try it!
