HifiBerry Amp+
Hello,
I already success to works my HifiBerry Amp+ on a RaspBerry Pi 2 loaded with Raspian + Kodi.
Now i try to have the sound with my HifiBerry Amp+ on a RaspBerry Pi 2 loaded with Rasplex 0.6.0.
As in the release note of RasPlex 0.6.0 it’s OpenELEC 5.0.7 : https://github.com/RasPlex/RasPlex/releases/tag/0.6.0
But it doesn’t work. (I start a topic in the HifiBerry Forum https://www.hifiberry.com/forums/topic/amp-rpi2-rasplex-0-60-openelec-5-0/)
As i already notice than in this post : https://forums.plex.tv/topic/154789-rasplex-with-hifiberry-dac-for-music-and-hdmi-for-movies/
KnightOrc says :
The dev team is working on integrating support for the HiFiBerry, it won't be in 0.6.0 but may be in 0.6.1.
But my concern is :
  1. Before the rasplex team release the 0.6.1, why i'm not able to hack rasplex 0.6.0 (based on OpenELEC 5.0.7) ?
  2. Are you aware than there is not a HifiBerry thing but many (Digi+, Dac+, Amp+...) ?
But my concern is :
  • Before the rasplex team release the 0.6.1, why i'm not able to hack rasplex 0.6.0 (based on OpenELEC 5.0.7) ?
  • Are you aware than there is not a HifiBerry thing but many (Digi+, Dac+, Amp+...) ?
In answer:
1. Because the code needs to be backported from Gotham/Helix to recognise the HiFiBerry as an Audio Ouput option and route the audio through it.
2. Really? Of course we are!
If you've seen the other topics why did you start a new one?
Regards
Thank you NedtheNerd for the answers.
I start a new topic because the other one was tag as HiFiberry DAC+ subject (and yes really I was not sure you were aware of the multiple cards from HifiBerry  ;)  ).
