there are the 5 files in osx folder
i dont seem to have daemons in my files
I would download the newest release of plexconnect https://github.com/iBaa/PlexConnect
Looks good to me, is it working then? I assume you edited the plist to your needs prior to installing it.
It is working now. Here what the problem was. The master file has plex.plexconnect_daemon.bash.plist.
The OSXautostart file has plex.plexconnect.bash.plist. That where my problem was . The OSX file would not work at all. The daemon file did. Thanks for all you help.
Weird everything looks fine on the main github installer, maybe you downloaded it prior to it being complete, strange:
https://github.com/iBaa/PlexConnect/blob/master/support/OSX/installdaemon.bash
now how do you check to see if it is running after a boot?
Whats your local ip, not wan ip obviously. This error response in the attached pic means its working, just enter in your local ip in safari to test after restart (post 72)
https://forums.plex.tv/topic/88975-plexconnect-running-on-any-jailbroken-ios-device/page-4#entry530826
Whats your local ip
??? why
Read prev post.
ok. did not know if there was a way in terminal
This is my surefire way to test that plexconnect is operational.
has this ever crashed on you?
The new daemon plist loaded via launchctl, so far no.
com.plex.plexconnect.bash.plist
createcert.bashinstall.bashremove.bashplexconnect.bash
This is actually good...
See my 1st post in this topic, post #10:
>> I actually prefer the second solution, see branch "OSXautostart". It fully works within the launchctl world, running PlexConnect.py directly. We might shift this back into "master" once the last quirks are solved.
The "daemon" stuff is from the current master branch... but it is not working correctly in regards of honoring launchctl commands.
Ok. How do we stop plexconnect. If we do an update.
Sent from my iPhone using Tapatalk
Post #9 within this topic.
quick note: I rolled branch "OSXautostart" over into "master".
-> If you installed it from old branch master, do a "remove.bash" before downloading the new stuff... or manually delete the file "/Library/LaunchDemons/com.plex.plexconnect_daemon.bash.plist"
