Using PlexConnect_daemon
I'll be the first to admit that I don't know much about anything when it comes to Linux.  Using Ubuntu 10.04, python 2.7 (one of a two versions installed)
When I execute:
sudo ./PlexConnect_daemon.bash start
i get a message indicating that it was successful.  When I use the status command, I'm told that it is running.  But when I click the trailers app on my ATV, it fails to load ("Trailers is unavailable.")  Since python 2.7 isn't the default version of python installed, I assume that it's trying to use 2.6 and this is causing problems (as this is the last problem I was having with getting Plexconnect to work at all.)
How do I get it to use python 2.7?
Not Ubuntu but maybe this will help.
https://forums.plex.tv/topic/97010-plexconnect-on-archlinux/
Also this which has Ubuntu:
https://forums.plex.tv/topic/71220-linux-install-for-plex-connect/
Start with then none deamon version and watch the output
add the following line to /etc/rc.local
python /usr/lib/PlexConnect/PlexConnect_daemon.py
save and restart - nothing more to do.  Obviously change the path to your PlexConnect installation to reflect your own installation.  I have this running on Lubuntu as a VM running on Vmware ESXI 5.5
Cheers,
Darren
Refering to the 2nd post, I have already done everything leading up to the "create init script" section.  So I create the script /etc/init.d/plexconnect as directed (using the Ubuntu script provided) and chown, chmod and update-rc.d
And then I go to start the service....and there's no service named plexconnect (?)
tom@HouseMedia:~$ sudo chown root:root  /etc/init.d/plexconnect
tom@HouseMedia:~$ sudo chmod 755  /etc/init.d/plexconnect
tom@HouseMedia:~$ sudo update-rc.d plexconnect defaults
update-rc.d: warning: plexconnect start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (3 4 5)
 Adding system startup for /etc/init.d/plexconnect ...
   /etc/rc0.d/K20plexconnect -> ../init.d/plexconnect
   /etc/rc1.d/K20plexconnect -> ../init.d/plexconnect
   /etc/rc6.d/K20plexconnect -> ../init.d/plexconnect
   /etc/rc2.d/S20plexconnect -> ../init.d/plexconnect
   /etc/rc3.d/S20plexconnect -> ../init.d/plexconnect
   /etc/rc4.d/S20plexconnect -> ../init.d/plexconnect
   /etc/rc5.d/S20plexconnect -> ../init.d/plexconnect
tom@HouseMedia:~$ sudo /sbin/service plexconnect start
sudo: /sbin/service: command not found
Although I am able to start it using: $sudo service plexconnect start
(I'm not sure if there is a difference between the two command line entries though)
The trailers app is still telling me that "Trailers is unavailable" and when I check on the status of plexconnect, I'm told it's not running
tom@HouseMedia:/var/run$ sudo service plexconnect start
* Starting the process PlexConnect
tom@HouseMedia:/var/run$ sudo service plexconnect status
 * PlexConnect process is not running
Im not sure to be honest with you. I would look through the Ubuntu link quite a bit to try to see what you may be missing. There are a number of sucessful attempts at getting plexconnect to load at boot on Ubuntu in there. I have used a ton of flavors of linux but I have never installed plexconnect on any of them. Its been a number of years since I have used linux, I currently run OSX all day.
Cheers,
Darren
I like this and I gave this a go; no luck.  I ensured the execution bit was set on /etc/rc.local as well.
what are the error messages you are getting?  anything in the logs?
also what do you see if you go to terminal and simply type in python /usr/lib/PlexConnect/PlexConnect.py
as the others wrote, start the python PlexConnect app manually and see the output first.
After that, create a symlink to /etc/init.d/plexconnect with full path to the bash init script and add it to upstart, thats actually it
I'm confused by your suggestion.
What path do I create the symlink (that points to /etc/init.d/plexconnect) in?  What "full path to bash init script" are you referring to?  Doesn't upstart require an entire script and not just a command?
My apologies for not including the details of my log / output when I run plexconnect manually, see below:
19:45:55 PlexConnect: started: 19:45:55
19:45:55 PlexConnect: Version: 0.3.1+
19:45:55 PlexConnect: Python: 2.7.5 (default, Feb  6 2014, 21:23:43)
[GCC 4.4.3]
19:45:55 PlexConnect: Host OS: linux2
19:45:55 Settings: getsetting enable_plexconnect_autodetect=True
19:45:55 PlexConnect: IP_self: 192.168.0.111
19:45:55 Settings: getsetting hosttointercept=trailers.apple.com
19:45:55 Settings: getsetting port_webserver=80
19:45:55 Settings: getsetting enable_dnsserver=True
19:45:55 DNSServer: started: 19:45:55
19:45:55 Settings: getsetting port_dnsserver=53
19:45:55 Settings: getsetting ip_dnsmaster=208.122.23.23
19:45:55 Settings: getsetting prevent_atv_update=True
19:45:55 DNSServer: ***
19:45:55 DNSServer: DNSServer: Serving DNS on 192.168.0.111 port 53.
19:45:55 DNSServer: intercept: ['trailers.apple.com'] => 192.168.0.111
19:45:55 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:45:55 DNSServer: forward other to higher level DNS: 208.122.23.23
19:45:55 WebServer: started: 19:45:55
19:45:55 WebServer: ***
19:45:55 WebServer: WebServer: Serving HTTP on 192.168.0.111 port 80.
19:45:55 ATVSettings: init class CATVSettings
19:45:55 ATVSettings: load settings
19:45:55 Settings: getsetting enable_webserver_ssl=True
19:45:55 Settings: getsetting port_ssl=443
19:45:55 Settings: getsetting certfile=./assets/certificates/trailers.pem
19:45:55 WebServer: WebServer: Serving HTTPS on 192.168.0.111 port 443.
19:46:07 DNSServer: DNS request received!
19:46:07 DNSServer: Source: ('192.168.0.164', 54767)
19:46:07 DNSServer: Domain: itunes.apple.com
19:46:07 DNSServer: ***forward request
19:46:07 DNSServer: -> DNS response from higher level
19:46:07 DNSServer: Source: ('192.168.0.164', 53778)
19:46:07 DNSServer: Domain: EVSecure-ocsp.verisign.com
19:46:08 DNSServer: DNS request received!
19:46:08 DNSServer: Source: ('192.168.0.164', 51238)
19:46:08 DNSServer: Domain: e5153.b.akamaiedge.net
19:46:08 DNSServer: ***forward request
as far as I can tell it is working correctly.
You need to do the following :
ln -s /etc/init.d/plexconnect /path/to/plexconnect/PlexConnect_daemon.bash
and then
That should actually do it
and then
No luck.
tom@HouseMedia:~/PlexConnect-master$ ln -s /etc/init.d/plexconnect /home/tom/PlexConnect-master/PlexConnect_daemon.bash
ln: creating symbolic link`/home/tom/PlexConnect-master/PlexConnect_daemon.bash': File exists
tom@HouseMedia:~/PlexConnect-master$ sudo update-rc.d plexconnect defaults
[sudo] password for tom:
 System start/stop links for /etc/init.d/plexconnect already exist.
And then I restart the system and have a look at what's happening...
 tom@HouseMedia:~/PlexConnect-master$ sudo service plexconnect status
tom@HouseMedia:~/PlexConnect-master$ sudo service plexconnect start
the log doesn't show anything new having happened and nothing on the ATV (including trailers) seems to be able to see the network.  I then start plexconnect manually and the ATV (including plexonnect)  works as it should again.  Even with PlexConnect clearly running (everything works) the plexconnect service insists that it has not been started.
if you already have a /etc/init.d/plexconnect file you can't create a symlink there.
Looking up how the ln command works, it appears that you're asking me to create a symlink named, "/PlexConnect-master/PlexConnect_daemon.bash" that references the location "/etc/init.d/plexconnect"   Is that what you're asking me to do?
Or should I be creating a symlink in /etc/init.d/plexconnect that references the PlexConnect_daemon.bash ???
it seems you're not dumb, you can figure this one out! :P I didn't look it up, just wrote how I remembered it. Just try it.
But as I said, it seems you had a init script there already, your errors before said so
Yep, not dumb, just confused.
I have deleted the existing /etc/init.d/plexconnect file and create the symlink but then I get this strange error doing update-rc.d:
tom@HouseMedia:/etc/init.d$ sudo ln -s /path/to/plexconnect/PlexConnect_daemon.bash /etc/init.d/plexconnect
tom@HouseMedia:/etc/init.d$ sudo update-rc.d plexconnect defaults
update-rc.d: /etc/init.d/plexconnect: file does not exist
tom@HouseMedia:/etc/init.d$ ls
alsa-mixer-save        lm-sensors                  sendsigs
anacron                lxdm                        single
apache2                mediatomb                   skeleton
apparmor               mgetty-fax                  smbd
atd                    module-init-tools           spamassassin
avahi-daemon           mt-daapd                    ssh
bacula-director        mysql                       stop-bootlogd
bacula-fd              networking                  stop-bootlogd-single
bacula-sd              network-interface           sysstat
bluetooth              network-interface-security  tightvncserver
bootlogd               network-manager             transmission-daemon
calibre                nmbd                        udev
clamav-daemon          ntp                         udev-finish
clamav-freshclam       ondemand                    udevmonitor
console-setup          plexconnect                 udevtrigger
cron                   plexmediaserver             ufw
cups                   plymouth                    umountfs
dbus                   plymouth-log                umountnfs.sh
dmesg                  plymouth-splash             umountroot
dns-clean              plymouth-stop               unattended-upgrades
dropbox                postfix                     urandom
failsafe-x             powernowd                   vboxautostart-service
fancontrol             powernowd.early             vboxballoonctrl-service
forked-daapd.dpkg-new  pppd-dns                    vboxdrv.dpkg-bak
grub-common            procps                      vboxweb-service
halt                   rc                          virtualbox-ose
hostname               rc.local                    webmin
hsf                    rcS                         wpa-ifupdown
hwclock                README                      x11-common
hwclock-save           reboot                      xdm
hylafax                rsync                       xinetd
irqbalance             rsyslog                     yum-updatesd
killprocs              screen-cleanup
But as you can see, /etc/init.d/plexconnect does indeed exist.
wtf....
yea, you created a symlink to /path/to/plexconnect/ which of course does not exist :D
You should replace that path with /home/tom/PlexConnect-master/PlexConnect_daemon.bash
a
ls -la
command in /etc/init.d/ will show that you basically directed that link to a nonexistent file. It does of course now exist but it doesnt point to anything so it actually does not exist :)
Very Schrödinger'esque ;)
yea sure, but why not :P
