How do I access PMS Packages?
Hello,
How do I import the PMS packages for usage with e.g tests?
AFAIK, you can’t :frowning:
But it’s just Python libraries? It should be possible to do modify sys.path with the libs from PMS?
Try, but tried again and again, and yet failed every time :frowning:
Unsure here, but suspect, that “It’s not just Python”, but also something from the closed sw, that kick’s in here, like access to the database :frowning:
