Server Version: 4.59.2
Player Version: 2.58.0.1076-38e019da
Hey, I want to conltrol my Plex HTPC with my Nintendo Switch Pro Controller. I tried to follow this article (Create your own inputmap | Plex Support) but it seems like it doesn’t work with HTPC so I tried it with the old Windows Plex Media Player. I found the controller id in the log file and created a json file as described. But when I press any button on my controller and close the player I can’t find any input log in the log file.
The log file part with the controller id:
2021-08-24 21:30:34 [ INFO ] InputSDL.cpp @ 207 - SDL found 1 joysticks
2021-08-24 21:30:34 [ INFO ] InputSDL.cpp @ 216 - JoyStick # 0 is Microsoft-PC-Joysticktreiber with 16 buttons and 4 axes
My json file:
"name": "Switch Pro Controller",
"idmatcher": "Microsoft.*",
"mapping":
"BUTTON_NAME_HERE": "function here",
//Here you can write comments
What am I doing wrong? The controller works fine with steam btw.
The first thing I need to do is find out what each button is called. According to the instructions, the best way to do this is to press the buttons and write down the commands.
Launch Plex Media Player and wait for it to finish loading
Press the desired button on your remote/controller
Look in the Plex Media Player.log file to see the button information
For instance, in the below log snippet, the PlayStation 3 controller was used. The X button was pressed first, then two seconds later the Square button was pressed.
With that information, you can then go to your skeleton inputmap file and change out the text BUTTON_NAME_HERE to read KEY_BUTTON_14 (or whatever button name you saw in the logs) instead. Repeat the process for other buttons.
My problem is that I don’t get those “Input received” log lines.
It looks like the player ignores the controller despite the idmatcher and does not accept any input commands, which is why I cannot read the input commands from the log file.
