I activated visualisers on iphone and ipad in Plex Amp but i still only see the album art. Im not seeing any visualisers. How do i activate it
Server Version#:
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I also keep selecting different visualisers but i don’t see any.
Clicking on the poster on the Now Playing screen should switch between poster and visualizer.
Long-pressing the poster/visualizer lets you pick which visualizer is being used.
It’s not working, long pressing does give me the option to select on but nothing happens once i select it. Same behaviour on iphone and ipad
Tap the poster while a song is playing
I did, it doesn’t work. I have tried tapping multiple times.
Aah ok, i was casting it to my apple tv. Playing it on ipad and it works now.
elan
May 27, 2022, 7:37pm
8
They only work when playing locally, otherwise it doesn’t have access to the audio data.
