@sickhouse said:
Working good with Let’s Encrypt! Here’s what I did, Plex/Synology - Custom domain with HTTPS - Album on Imgur
Thank you so much for this solution. Works flawlessly! ![]()
I update some elements on my script, here it is :
#!/bin/sh
#This script will create a new p12 certificate for Plex
#when Let's Encrypt automatically renew its one
#Mathieu Noublanche - 2017-08-10 v0.3
#Just adapt the values below to your configuration
#Location of your script
script_folder=/volume1/scripts
#Folder and name you want for your p12 file
p12_file_path=$script_folder/syno.p12
#Add password to the p12 file (you can leave it empty)
p12cert_password=
#Synology's Default Let's encrypt folder
letsencrypt_cert_folder=/usr/syno/etc/certificate/system/default
#Changes below are at your own own risk
generate_p12=false
current_date=`date +"%s"`
current_certificate_date=`openssl x509 -enddate -noout -in $letsencrypt_cert_folder/cert.pem | cut -d'=' -f2`
current_certificate_timestamp=`date -d "$current_certificate_date" +"%s"`
#First of all, we check if the renew_timestamp file exists (this file keep in memory the further certificate renew date)
if [ ! -f $script_folder/renew_timestamp ]; then
echo "Generate timestamp for the current renew date... "
echo $current_certificate_timestamp > $script_folder/renew_timestamp
chmod +rw $script_folder/renew_timestamp
chown admin:users $script_folder/renew_timestamp
#We generate the first p12 file
generate_p12=true
else
renew_date=`cat $script_folder/renew_timestamp`
echo "In memory certificate expiration date is" `date -d @$renew_date` "and the current certificate expiration date is $current_certificate_date"
#Now, we check if is it necessary to renew the certificate or not
if expr "$current_certificate_timestamp" "!=" "$renew_date" > /dev/null; then
#We ask to generate a new p12 file
echo "Dates doesn't match, we have to renew the certificate..."
generate_p12=true
#We update the timestamp_date on the file
echo "Updating the new timestamp date..."
else
echo "It is not necessary to renew the certificate, abort."
exit 0
fi
fi
#We generate a new certificate file if we ask it, ans we relaunch Plex App to take effect
if expr "$generate_p12" "=" "true" > /dev/null; then
echo "Generating the p12 certificate file..."
openssl pkcs12 -export -out $p12_file_path -in $letsencrypt_cert_folder/cert.pem -inkey $letsencrypt_cert_folder/privkey.pem -certfile $letsencrypt_cert_folder/chain.pem -name "Domain" -password pass:$p12cert_password
chmod +r $p12_file_path
chown admin:users $p12_file_path
echo "Relaunching Plex App..."
sh /var/packages/Plex\ Media\ Server/scripts/start-stop-status stop
sh /var/packages/Plex\ Media\ Server/scripts/start-stop-status start
echo "Done."
fi
Sorry duplicate post !
@Mathieu: Thank you very much!
WORK GREAT, thank you so much!! ![]()
@“Mathieu Noublanche” said:
Hi,I update some elements on my script, here it is :
#!/bin/sh ######################################################## #This script will create a new p12 certificate for Plex #when Let's Encrypt automatically renew its one #Mathieu Noublanche - 2017-08-10 v0.3 ######################################################## ######################################################## #Just adapt the values below to your configuration #Location of your script script_folder=/volume1/scripts #Folder and name you want for your p12 file p12_file_path=$script_folder/syno.p12 #Add password to the p12 file (you can leave it empty) p12cert_password= #Synology's Default Let's encrypt folder letsencrypt_cert_folder=/usr/syno/etc/certificate/system/default ######################################################## #Changes below are at your own own risk ######################################################## generate_p12=false current_date=`date +"%s"` current_certificate_date=`openssl x509 -enddate -noout -in $letsencrypt_cert_folder/cert.pem | cut -d'=' -f2` current_certificate_timestamp=`date -d "$current_certificate_date" +"%s"` #First of all, we check if the renew_timestamp file exists (this file keep in memory the further certificate renew date) if [ ! -f $script_folder/renew_timestamp ]; then echo "Generate timestamp for the current renew date... " echo $current_certificate_timestamp > $script_folder/renew_timestamp chmod +rw $script_folder/renew_timestamp chown admin:users $script_folder/renew_timestamp #We generate the first p12 file generate_p12=true else renew_date=`cat $script_folder/renew_timestamp` echo "In memory certificate expiration date is" `date -d @$renew_date` "and the current certificate expiration date is $current_certificate_date" #Now, we check if is it necessary to renew the certificate or not if expr "$current_certificate_timestamp" "!=" "$renew_date" > /dev/null; then #We ask to generate a new p12 file echo "Dates doesn't match, we have to renew the certificate..." generate_p12=true #We update the timestamp_date on the file echo "Updating the new timestamp date..." echo $current_certificate_timestamp > $script_folder/renew_timestamp else echo "It is not necessary to renew the certificate, abort." exit 0 fi fi #We generate a new certificate file if we ask it, ans we relaunch Plex App to take effect if expr "$generate_p12" "=" "true" > /dev/null; then echo "Generating the p12 certificate file..." openssl pkcs12 -export -out $p12_file_path -in $letsencrypt_cert_folder/cert.pem -inkey $letsencrypt_cert_folder/privkey.pem -certfile $letsencrypt_cert_folder/chain.pem -name "Domain" -password pass:$p12cert_password chmod +r $p12_file_path chown admin:users $p12_file_path echo "Relaunching Plex App..." sh /var/packages/Plex\ Media\ Server/scripts/start-stop-status stop sh /var/packages/Plex\ Media\ Server/scripts/start-stop-status start echo "Done." fi
Thank you very much for this excellent script! Works like a charm!
My only problem left is that the Android client doesn’t pick up my custom domain when I try to cast to Chromecast. It still uses the plex.direct address. This doesn’t work because the server answers with my custom certificate. The IOS client on the other hand sends the correct address to the Chromecast and everything works. Any ideas?
Thank you, Works like a charm ! <3
