How to create a .plexapp file
Hi, this is probably a dumb question, but hopefully that means a simple answer.
I use raindancing’s awsome moviedb.org plugin for all my MMA (UFC, Pride, etc) stuff
http://forums.plexapp.com/index.php/topic/22094-themoviedb-standalone-agent/
Unfortunately it had a small bug in it (logging binary data) which I fixed with a simple one line change (comment out the Log).
So I am wondering how I can build a new .plexapp file which I could attatch to the above forum topic for other users.
.plexapp files are no longer a recommended means of distributing plugins/agents/etc. They only work on Mac OSX which tends to cause problems for the Windows and Linux users in the crowd. The best option is to distribute the .bundle file in a zip archive. Then users are responsible for installing themselves. Alternatively, you can add the plugin/agent to the Unsupported Appstore (check my sig for the link).
OK, thanks for the tip. I went with a .zip
Thanks again
