How to export existing posters?
Is that from ExportTools?
No, that was from ā€œFind Unmatched Filesā€. What do you mean ā€œExportToolsā€? Is this part of this tool?
On a cell right now, so limited access. Search for ExportTools and you’ll find what you need
And findumatched is dead. Look up Webtools
Then you can just open it right away and get each pathname on a new line in your excel document. Just like you need to use the above tool to create the folders for you.
Windows10 doesn’t even have Excel but I’ll try and find an alternative in Microsoft Store and play with it. And I’ll try the ExportTools program search too. Thanks
Ok, I found an old copy of Office 2000 and installed Excel.
So, my movie titles are listed in column ā€œGā€ and their year of release in column ā€œAJā€. Seeing my folder name format was ā€œMovie Title (year)ā€ , how do I configure the macro to create the folders in this same format, using both column G & AJ? Example: Charlie’s Angels (2000). Also, what do I do with this code once It’s configured properly? Thanks
That is a Q for MS Excel forums, IMHO
Also use the column named Part File Path for the directory creation :wink:
Update: All my lost directories have now been restored, along with their posters and fanart, thanks to MovieFan editing his tool for me! Thanks MovieFan! Your Database Tool for Plex ROCKS!
Hi, do you still have this zip file? i cant see a link my end.
