How to Implement existing XBMC scanner to Plex
Hungarian PORT.hu XBMC scanner. I would pay for that if needed
Can I modify an existing XBMC scanner to Plex ?
If it is not possible I would pay some money for that if anybody can do.
That would be more trouble than rewriting it from scratch.
I’ll look in to it shortly. If I need your help translating I’ll let you know.
You can paypal me a bottle of Egri Bikaver when I’m done :slight_smile:
Thank You in advance, you arevery kind.
Where from do you know Egri Bikaver?
Anyway, if you are hungarian we can talk to hungarian as well.
If you can do it to me I would like you to suprise with my favorit wine ( what is not Hungarian to be the honest ).
Do you have any planed deadline?
Anything has happened?
Do you stil plan implementing port.hu scrapper or should I give it up?
Thank you for your answer in advance.
:huh:
Hi György!
I've implemented a simple Port.hu scrapper for Plex. It's not online anywhere yet, beacuse it's in pretty much beta so far. I can send it to you for betatesting, so please contact me in a PM, and we can discuss it more easily in hungarian :)
üdv
Sanyi
I’ve created a pretty much stable version of the plugin lately, so I’ve uploaded it to GitHub and created a page at the Plex Wiki: http://wiki.plexapp.com/index.php/Port.hu (Also added to the Unsupported plugins page on the Wiki)
There are some installation instructions in hungarian at the bottom. Bug reports are appreciated.
Sanyi
Kedves Sanyi,
Két év után most tértem vissza a Plex-hez, eddg XBMC-t használtam alapvetően két ok miatt amiből az egyik pont a magyar scrapper hiánya volt (ami másik hogy nem kezelte az ISO file-okat).
Fantasztikus jó munkát végeztél, szóval az ígért Bikavér minimum jár Neked. Mikor adhatom át és hol?
Sokan használjuk a programodat?
Üdv,
Gyuri
A bikaver atadasarol meg nem mondtam le
