How to make a pdf from film library please?
how to make a pdf from my film library , e.g. 1 page to scroll down endless?
i tried “print to pdf” it worked! but it was only 1 page with 10 films and i have many more.
i have latest plex server on osx 15.4.1, apple mbp m1
thanks
What exactly are you trying to achieve?
Saving a list to PDF will mostly be subject to the browser’s capabilities (e.g. to scroll/print the full library instead of taking just the initial view / first viewport page).
If you just want a list of your media, you might instead want to look at WebTools-NG‘s Export Tools.
thanks i am trying webtools ng now!
i want a visual overview, exactly like the library looks, thumbnails of films to scroll down
For what purpose that the Plex apps / web page don’t cover?
purpose: to show film lib. to friend, who cant install plex on his non smart tv
i tried web tools ng, i couldnt make a thumbnail overview of my whole filme library, exactly it is shown in plex client to scroll down.
so thats not possible, i guess.
never mind, i can do lots of screenshots, thats a bunch.
thanks
Webtools will export a plain list of your movies.
Your friend can access Plex in a browser. If you’ve shared a library with them, they can then see it there.
If that friend can look at a PDF, they can open the Plex web app as well and scroll through your library.
Looking for something like this, right?
I went into chrome, and used this add-on.
GoFullPage Link.
While in chrome I login to the plex web UI and go into my library. Then I select it to do a full screen capture.
When you right click the preview image you would select “save as pdf.”
right! easy
solved
thanks!
