I am using Last.FM for my music library #1 but I plan on switching over to the new Plex scanner. I will be creating a new library instead of risking ruining my current library with Last.FM.
I did a sonic analysis on my original last.fm library which took almost a week.
How can I save the sonic analysis in order to not have to redo the analysis all over again on the new library?
Unfortunately you cannot.
Do you know where the sonic analysis is saved to?
I have a rough idea:
The result of each album’s analysis is first stored in the metadata package of this album. The metadata packages are stored in a hierarchical folder structure inside the plex data folder. It is not easy to find out which folder is for which media item.
After all albums have been analysed, these results are being copied into a SQLite database, which is stored in a subfolder of the folder where the primary Plex database file is located: Plex data folder/Plug-in Support/Databases/Music Analysis n
If you deleted this database, it will be rebuilt from the analysis results which are stored inside the metadata packages.
Here are my logs maybe you guys can shed light onto what’s going on under the hood please
Plex Media Server Logs_2021-10-26_05-38-06.zip (3.5 MB)
