How to switch to a minute of a movie.
I looked for but didn’t find.
Is there the possibility to go directly for example to minute 50 of a movie?
I found fast forward but not goto minute.
Tnx
Same question asked a couple of weeks ago, key in 50:00 (5000) on the number buttons and then press enter, uses minutes and seconds, so 0050 would be 50 seconds and so on.
Regards
Tnx,
really i’ve already asked?
I didn’t remember.
I’m afraid i’m going crazy :smiley:
@fbrassin said:
Tnx,
I didn’t remember.
:slight_smile:
He didn’t say that you were the one to ask, but only that the question as such has been asked before.
In any case, the entry format for this ‘timestamp jump’ is very flexible, and deserves some clarification.
If you enter less than three digits it’s accepted as seconds from video start.
If you enter less than 5 digits it’s accepted as minutes and seconds from video start.
If you enter more than 4 digits it’s accepted as hours, minutes and seconds from video start.
If you want jumps relative to current position, then you need to use arrow keys (or DPad buttons) instead.
Right/Left jump forward/back 30/15 seconds respectively.
Up/Down jump forward/back 10 minutes.
NB:
Arrow jumps beyond the end of a video will normally end playback, but digit entry jumps will not.
If the entered time value exceeds the video duration the command will just be ignored.
Best regards: dlanor
dlanor, tnx for your clear explanation.
Ps.
I’m afraid i was the one who asked in the other post :slight_smile:
