How can i connect to the PMS API when Plex Home is active? Usually i got to http://Serveradress:32400/ and get an xml with available options. But when Plex Home is active i get only 401 errors.
Start by going two posts up, to the pinned ones ;-)
https://forums.plex.tv/topic/129922-how-to-request-a-myplex-token-for-your-app/
the answer isn't there. only someone with a similar problem - once home is active the tokens alone don't work anymore
Wrong.....You'll from your app need to provide the token, preferred in the header of your request
To request a token, look @ the pinned post, or here
To see a sample code, look @ like my Plex2CSV
/T
