HTTP.Get troubles
I am trying to use the Http.Get and GetCached methods but I keep getting an error message and I cannot figure out what is going on. It must be sonmething silly, here is my code :
[codebox]
import PMS
from PMS import Plugin, Log, XML, HTTP
from PMS.Objects import *
from PMS.Shortcuts import *
import re
(… CUT TOP OF THE SOURCE …)
def sub_category (sender, path , title = None, replaceParent=False, values=None):
dir = MediaContainer(title1="", title2=title, replaceParent=replaceParent)
player_address = WEB_ROOT+’/player/’+path
html = PMS.HTTP.Get(player_address)
[/codebox]
and I get the following error in the log :
[codebox]
13:03:52.493237: com.plexapp.plugins.PLUGIN : (Framework) Calling named function ‘sub_category’
13:03:52.498725: com.plexapp.plugins.PLUGIN : (Framework) An exception happened:
Traceback (most recent call last):
File “/Library/Application Support/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/1/Python/PMS/Plugin.py”, line 464, in __call
return function(*args, **kwargs)
File “/Library/Application Support/Plex Media Server/Plug-ins/JTFrance2.bundle/Contents/Code/init.py”, line 105, in sub_category
AttributeError: ‘module’ object has no attribute ‘Get’
13:03:52.501979: com.plexapp.plugins.PLUGIN : (Framework) Request not handled by plug-in
[/codebox]
I took a peek at other plugins and I do not see what I am doing different
I have tried HTTP.Get, HTTP.GetCached, PMS.HTTP.Get, PMS.HTTP.GetCached , no luck, I am about to try banging my head harder on my desk but I am not sure it will help … :slight_smile:
Any suggestion ?
Sorry it took so long for an answer!
For a V1 plug-in use HTTP.Request, which automatically caches. HTTP.Get / HTTP.GetCached were older V0 API calls.
no worries and thanks for the answer I will try it ASAP.
