I'm running Plex on Win 8.1, but I need to be able to run it on a Vista Machine.
I’m running Plex on Win 8.1, but I need to be able to run it on a Vista Machine. When I try to log on with my email and password, nothing happens. The Vista version of Plex is 9.5.2. Am I missing something or do I need the Premium Package to do that? Thank you.
Hello,
Take a look please.
I understand that Vista is no longer supported, but I have it loaded and I’m using it. I just needed to log on to my account through it so I didn’t have to reload info into my Roku boxes. And I didn’t really want to sign up for another free account. So should I be able to log on to my account through Plex server running on my Vista Machine? Or is this a Premium feature?
Vista is not supported by Microsoft and therefore will not get any security updates any more.
If you still use Vista, then I recommend to immediately stop and update to a newer and secure OS.
I’m confused. You have PMS 0.9.5.2? That is really, really, really old. Did you mean 0.9.15.2? If you got PMS installed, then it should still work but will be very limited.
Yes. This should still work.
