[Implemented] Add support for av1 coding standard
+1 for av1 support and transcoding
+1 for av1 support
+1 here also
+1 for AV1 too
+1 for me, too
The newest Roku Ultra announced today has av1 hardware decoding.
This is a MUST have now.
how has that not been added yet
+1 for av1 codec
So sad that we need to request new codes for this platform when others just stay on top new tech without asking. Always the same with Plex.
I suspect they are busy with the new internet feed sources. I would hope that someone doesn’t come out with an alternative that strips out all that, and only plays local content as well as Plex used to. That would be the beginning of the end for them. I’ve even seen reports that Plex sometimes won’t access local content without an internet connection, although it would not be needed, for that purpose.
+1 for AV1 support.
+1 for AV1 support.
+1 for AV1 support. My new Samsung TV supports AV1 natively and I have confirmed this using a flash drive. It would be nice to use Plex instead.
+1 for AV1 support
+1 for AV1 support
This suggestion isn’t a replacement for supporting AV1/AV01, but perhaps helpful until it’s supported.
Is video from YouTube a primary use-case for this?
YouTube typically encodes video into lots of formats, and serves up whatever version the client requests. Many video downloaders allow you to specify the format to fetch.
An example - with youtube-dl, get a list of formats:
% youtube-dl --list-formats "https://www.youtube.com/watch?v=dQw4w9WgXcQ"
[youtube] dQw4w9WgXcQ: Downloading webpage
[youtube] dQw4w9WgXcQ: Downloading js player 1a1b48e5
[info] Available formats for dQw4w9WgXcQ:
format code  extension  resolution note
249          webm       audio only tiny   49k , opus @ 50k (48000Hz), 1.18MiB
250          webm       audio only tiny   65k , opus @ 70k (48000Hz), 1.55MiB
140          m4a        audio only tiny  130k , m4a_dash container, mp4a.40.2@128k (44100Hz), 3.27MiB
251          webm       audio only tiny  136k , opus @160k (48000Hz), 3.28MiB
394          mp4        256x144    144p   75k , av01.0.00M.08, 25fps, video only, 1.75MiB
278          webm       256x144    144p   88k , webm container, vp9, 25fps, video only, 2.08MiB
160          mp4        256x144    144p  113k , avc1.4d400c, 25fps, video only, 2.79MiB
395          mp4        426x240    240p  159k , av01.0.00M.08, 25fps, video only, 3.48MiB
242          webm       426x240    240p  192k , vp9, 25fps, video only, 4.32MiB
133          mp4        426x240    240p  250k , avc1.4d4015, 25fps, video only, 6.16MiB
396          mp4        640x360    360p  332k , av01.0.01M.08, 25fps, video only, 6.94MiB
243          webm       640x360    360p  411k , vp9, 25fps, video only, 9.06MiB
397          mp4        854x480    480p  595k , av01.0.04M.08, 25fps, video only, 12.09MiB
134          mp4        640x360    360p  636k , avc1.4d401e, 25fps, video only, 12.99MiB
244          webm       854x480    480p  757k , vp9, 25fps, video only, 15.90MiB
398          mp4        1280x720   720p 1125k , av01.0.05M.08, 25fps, video only, 22.93MiB
135          mp4        854x480    480p 1170k , avc1.4d401e, 25fps, video only, 26.07MiB
247          webm       1280x720   720p 1522k , vp9, 25fps, video only, 32.56MiB
399          mp4        1920x1080  1080p 2084k , av01.0.08M.08, 25fps, video only, 41.70MiB
136          mp4        1280x720   720p 2318k , avc1.4d401f, 25fps, video only, 53.38MiB
248          webm       1920x1080  1080p 2677k , vp9, 25fps, video only, 60.78MiB
137          mp4        1920x1080  1080p 4466k , avc1.640028, 25fps, video only, 107.66MiB
18           mp4        640x360    360p  601k , avc1.42001E, 25fps, mp4a.40.2@ 96k (44100Hz), 15.19MiB (best)
Download video format ID 137 and audio 251 and combine them:
% youtube-dl -f 137+251 --merge-output-format mp4 "http://www.youtube.com/watch?v=dQw4w9WgXcQ"
Or grab the lower resolution but already-combined H.264 + MP4A version:
% youtube-dl -f 18 "http://www.youtube.com/watch?v=dQw4w9WgXcQ"
AVC1 is our old friend H.264. It’s confusing to see that in a thread about AV1/AV01, with the similar-looking name.
+1 for av1 support !
+1 for AV1 support!
Hay algĂșn avance con el codec AV1 o no se va a incorporar en Plex?
+1 para soporte AV1!
