[Implemented] Playlist settings in Dash, Plexamp, Mobile App
Right now, the only way to edit a playlist’s cover photo, name, and description is through the web app. This is especially annoying, since you can create a playlist in Plexamp, for example, but then be unable to edit it from within the app. You can change specific albums’ cover photos on Dash, but why not playlists’ as well?
Semi related, but custom playlist cover photos do not appear in the Plex mobile app.
This is no longer the case. Plexamp can now be used to both create and edit playlists, and as of v4.9.0 it can also upload custom posters.
I just tested on Android mobile, and I believe this is also no longer the case :slight_smile:
